    Virtual (shadow) drives
    Firmware wishlist
    • Nuramoriundefined
      Nuramori
      I was hoping (looking) for a way to effectively create a virtual variant of a drive, so that the same motor could operate under different settings, but be used as effectively as a different, addressable drive. for instance, if we had in our config.g file the following:
      M584 E0.6
      M569 P0.6 S0
      M563 P0 S"main filament" D0 H1 F0
      that I could also then make a shadow version of the one motor to for all intents and purposes be driven as a different motor when associated with another tool (printhead), like so...
      M584 E0.6:0.6!
      M569 P0.6 S0
      M569 P0.6! S1
      M563 P1 S"support filament" D1 H1 F0
      I'm looking for a way to design something to use one motor, but operate in reverse when set to be a "different" head.
      • o_lampeundefined
        o_lampe @Nuramori
        @nuramori
        Can't you just define two different M569 in the tool change macros?
        Nuramoriundefined 1 Reply Last reply Reply Quote 0
        • Nuramoriundefined
          Nuramori @o_lampe
          @o_lampe hmmm, can you modify the motor on the fly like that? if so, then I think that would work.
          • o_lampeundefined
            o_lampe @Nuramori
            @nuramori
            @dc42 said, I could change the whole kinematic model 'on the fly', so it's worth a try..
            Some parameters can't be changed mid-print, it would be nice to have a table about those do's and don'ts
