    read "M260 Amm Rnn" into variable?
    Gcode meta commands
    read i2c
    616
    • o_lampe
      o_lampe last edited by o_lampe
      Hi gents,
      I want to read a value from I2C bus into a variable.
      The command for that is
      M260 A{slaveAddress} R{number of bytes}
      Would it be as simple as
      set var.received_value = M260 A8 R6
      • o_lampe
        I can succesfully send 3 bytes to an ArduinoDue and also receive an answer. I also tried ESP32, but got compiler-errors. (Not a concern for the Duet team.)
        But it sucks, that I can't express the data in HEX. (only the address is possible in HEX)
        Another thing unclear: are pullups activated on TWCK and TWD0?
        o_lampe 1 Reply Last reply Reply Quote 0
        • o_lampe
          o_lampe @o_lampe last edited by
          @o_lampe said in read "M260 Amm Rnn" into variable?:
          can receive an answer.
          That answer only appears in the console, but I can't read it into a variable. What is an I2C-read function good for, when you can't work with it?
          How do we read sensor values coming from serial, I2C or SPI into a variable?
            dc42 administrators @o_lampe last edited by
            @o_lampe, is it just 1 byte that you need to read in a single M260 command, or multiple bytes?
            • o_lampe
              o_lampe @dc42 last edited by
              One byte would be a starting point, but I'm looking for a more general solution. The barometric sensor I have in mind has a resolution of 24bit.
              It seems, if I have a sensor which isn't predefined in RRF, I can only use M308 Y-types like 'linear-analog' or 'drivers'
              (no further details in the Wiki about the resolution of the linear-analog, or any info about the drivers-type?)
              I could use the 12-bit DAC of the ArduinoDue to send info back to the Duet. That seems easier than trying to store the M260 return value(s) to a variable.
              dc42 o_lampe 2 Replies Last reply Reply Quote 0
                @o_lampe, which baro sensor is it?
                • o_lampe
                  o_lampe @dc42 last edited by o_lampe
                  I want to start with the GY-63 (MS5611) module, but here
                  we've discussed other candidates as well. Other candidate is 'NBPLANN150PAUNV '.
                  They all have a digital interface. A new sensor type, I wish we could define as user in RRF. It's hard to build a 'proof of concept', when we don't have a way to talk with them.
                  • o_lampe
                    o_lampe @o_lampe last edited by o_lampe
                    It seems to work, but I'm a bit confused about the decimal point. Still don't know what the AD-conversion resolution of the Zprobe.in pin is?
                    As shown, I sent '255:255:255' to the Due and the answer is scaled down to 255.
                    I wish, I had some equipment to test the latency from
                    • sending 3 bytes over I2C
                    • convert to analog in the Due
                    • Zprobe.in shows the new value
                    Here's the Due file, if anyone is eager to test it:
                    Due_I2C_Slave_analogOut.txt
                    //edit
                    The sensor reading seems to toggle between 0.6 and 254.9. No readings in between. Seems, the DA conversion isn't a real analog thing. Maybe try the real DAC-output of the Due instead...
                      dc42 administrators @o_lampe last edited by dc42
                      Have you considered the BMP280, https://www.adafruit.com/product/2651? We've had other interest in using this, so we may write a driver for it.
                      Edit: looks like the BMP388 is even better, https://www.adafruit.com/product/3966.
                      • o_lampe
                        Will look at it, thanks for supporting this idea.
                        The analog datatransfer is a bit messy,
                        I get different results from filtered reading vs unfiltered and the DAC output is again different. (real AC with neg. amplitude?)
                        • o_lampe
                          @dc42 said in read "M260 Amm Rnn" into variable?:
                          I agree, writing a init-rotine for a sensor and support all the features it has, is not beginners-stuff. But it would be nice to have a generic digital type of sensor we could use for our own implementations.
                          • o_lampe
                            would it be possible to use the 'result' function for reading the returned value? Right now it only reports the outcome of a command, but not a read value.
                            set var.return_value = result (M260 An R3)
                            JD 1 Reply Last reply Reply Quote 0
                            • JD
                              JD @o_lampe last edited by
                              @o_lampe @dc42
                              Just adding that I would also like to see a general I2C read response parser or variable assignment that we can use for conditions in meta command programming. For instance, we have an I2C realtime clock calendar IC attached to a Duet2. We would like to use it to trigger g-codes at certain times of the day.
                              Currently, we use the http interface to send an I2C command to program the current time of day and an alarm time in to the RTCC IC. Then we use a single alarm interrupt output pin from a single RTCC IC to trigger an endstop input that runs a triggerX.g file and we put our gcode commands in the trigger gcode file. This method is limited to the one time of day.
                              If we were able to arbitrarily query the TOD from the rtcc from gcode running standalone (no web,telnet,panel etc) we could develop some more useful gcodes.
                              We also see some utility for some other i2c devices
                              JD
                                dc42 administrators @JD last edited by
                                @jd I've added this to the firmware wish lit for consideration in RRF 3.5.
                                jay_s_uk 1 Reply Last reply Reply Quote 0
                                • jay_s_uk
                                  jay_s_uk @dc42 last edited by
                                  @dc42 any chance of the current 3.5 wishlist being made available?
