Hard reset Duet 2 WiFi by accident.
@jay_s_uk will give it a bash, and get back to you.
Hi I edited the Config.g folder and still cant get the module to idle.
@dc42 hi im still getting nothing, module wont idle, just returns okay
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2<LF>ok<LF>
M552
WiFi module is disabled<LF>ok<LF>
M552 S0
ok<LF> -
@jamiebrown, what happens if you send M997 S1 without sending the M552 S0 command first?
@jamiebrown what do you also get if you send M552 by itself?
ok is a normal response -
M997 S1
Trying to connect at 230400 baud: success<LF>Erasing 4096 bytes...<LF>Erasing 212992 bytes...<LF>Uploading file...<LF>5% complete<LF>10% complete<LF>15% complete<LF>20% complete<LF>25% complete<LF>30% complete<LF>35% complete<LF>40% complete<LF>45% complete<LF>50% complete<LF>55% complete<LF>60% complete<LF>65% complete<LF>70% complete<LF>75% complete<LF>80% complete<LF>85% complete<LF>90% complete<LF>95% complete<LF>Upload successful<LF>ok<LF> -
@jay_s_uk m552
WiFi module is being started<LF>ok<LF>
m552 s0
ok<LF>
m552 s0
ok<LF>
m552 s-1
WiFi module stopped<LF>ok<LF>
m552 s0
ok<LF> -
@jamiebrown thats flashed fine then.
Send M552 S0
wait a few seconds
Then Send M552 so make sure its gone idle
Then send M587 with your wifi credentials
Then send M552 S1 -
@jay_s_uk that seems to have worked i can get to the web interface now. Thanks so much...
but in order for it to remember the access point is there anything i need to do before unplugging the usb? -
@jamiebrown the wifi details are stores on the ESP8266.
As long as you have M552 S1 somewhere in your config you'll be fine -
@jay_s_uk Thank you so much for your patience in dealing with my absolute lack of knowledge.
