    Using the RepRapFirmware Configurator
    Firmware installation
    • PCNoobNeedsMajorHelpundefined
      Total noob when it comes to programming and Gcode etc...
      That being said I need a lot of help.
      • Ok so I have a Duet 2 Wi-Fi and I've got it as far as connecting it to the DWC.
      • All of my wiring is done because I actually know how to do that and now I'm stuck at the configuration tool inputs. STEP 3.) Configuration (General Cartesian)
      • I don't know what any of it means and its all very confusing. I didn't know I needed my configuration file from my old board or I would've made sure to save a copy.
      *Is there a preloaded zip file I can access?
      Here is my setup:
      -Ender 5 Printer (Cartesian )
      -400mm screw (I think)
      -Duet 2 Wi-Fi: -Firmware version: N/A. -Firmware Name: N/A. -Web interface version 1.13
      -Thermocouple Daughter Board
      -Thermocouple Type K
      -60w 24v Heater Cartridge in a copper block
      -Direct Drive set up
      -5i PanelDue (never been used)
      -Mean Well power supply
      Everything else on the printer is stock
      Please Help. Thanks in advance
      -Carson
        You're in luck as there is a multipart guide on converting an Ender 3 to use the Duet Maestro. Not exactly the same as yours but pretty close and will give you a better idea of the process., starting with wiring.
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
        PCNoobNeedsMajorHelpundefined 1 Reply Last reply Reply Quote 0
          PCNoobNeedsMajorHelp @Phaedrux
          @phaedrux
          Thank you, this definitely helps! Do you know of any links or .json files that have the Ender 5 values already plugged in? If not, how do I measure those values, because I can't find them in the config.h file for the Ender 5 on it's Marlin V1.1.4 board via Arduino IDE.
          Thanks in advance!
          -Carson
          jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @PCNoobNeedsMajorHelp
            @pcnoobneedsmajorhelp we have an ender 5 plus config here which is similar https://github.com/TeamGloomy/LPC-STM32-RRFUserConfigs/tree/master/Ender 5 Plus - SKR 1.4 Turbo - ESP - rizast
            Be warned that the wiring to the y-axis at least is a ribbon cable with 6 wires. We've had a number of users who had false positives whilst homing. The fix is to separate the two endstop cables away from the ribbon.
              Phaedrux Moderator @PCNoobNeedsMajorHelp
              @pcnoobneedsmajorhelp said in Using the RepRapFirmware Configurator:
              You can start with the Ender3 profile in the config tool. It's nearly identical.
