    Laser control failed
    Laser Cutters
    • guanjian
      guanjian last edited by
      I made the circuit board according to the instructions on the official website, but after connecting it to the duet, it can’t work properly. I can’t control the laser switch and intensity using instructions such as M3.M5 G1 Sx.
      I have measured it, the power supply is normal, and my laser module also meets the specifications. The pwm port has a 5V output, no matter what G code I use, the 5V voltage does not change.
      I made M452 C "exp.heater3" R255 F200 into a macro, and I opened it when I needed it.
      The above is generated using Google Translate. If there is any unclear description, please let me know.
        Can you provide the results of sending M122 so we can get some more details about your setup like what duet board and firmware version you're using?
        Can you also share your config.g and other files that are being used to configure.
        Showing a photo or diagram of your wiring could also be useful.
        guanjian 2 Replies Last reply Reply Quote 0
        • guanjian
          guanjian @Phaedrux last edited by
          @phaedrux M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta3 (2021-04-22 16:27:28) running on Duet WiFi 1.02 or later
          Board ID: 08DGM-9T6BU-FG3S4-6JKF0-3SD6L-1URRF
          Used output buffers: 13 of 24 (13 max)
          Static ram: 23156
          Dynamic ram: 75356 of which 12 recycled
          Never used RAM 15892, free system stack 186 words
          Tasks: NETWORK(ready,11.2%,211) HEAT(delaying,0.0%,294) Move(notifyWait,0.1%,214) MAIN(running,87.5%,463) IDLE(ready,1.2%,19), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:18 ago, cause: power up
          Last software reset at 2021-04-25 11:24, reason: User, GCodes spinning, available RAM 15892, slot 2
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 23.5, current 24.8, max 25.2
          Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-04-25 11:25:23
          Cache data hit count 676672059
          Slowest loop: 5.36ms; fastest: 0.18ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.3ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Filament sensors ===
          Extruder 0 sensor: ok
          === Network ===
          Slowest loop: 81.88ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address cc:50:e3:27:3f:07
            WiFi Vcc 3.42, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 19608
            WiFi IP address 192.168.123.36
            WiFi signal strength -45dBm, mode none, reconnections 0, sleep mode modem
            Clock register ffffffff
            Socket states: 4 4 0 0 0 0 0 0
          This is M122's reply
          • guanjian
            i use a 4p jumper to connect the duet and laser board,42ba664b-c2c7-43e9-8449-439bf5770101-image.png
            • guanjian
              guanjian 1 Reply Last reply Reply Quote 0
              • guanjian
                guanjian @guanjian last edited by
                @guanjian ; Configuration file for Duet WiFi (firmware version 3)
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 05 2020 10:37:58 GMT+0800 (中国标准时间)
                M550 P"BLV" ; set printer name机器名字
                M669 K1 ; select CoreXY mode机器模式
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S1 ; enable FTP
                M586 P2 S1 ; enable Telnet
                M569 P0 S1 ; physical drive 0 goes forwards,X电机方向和位置
                M569 P1 S0 ; physical drive 1 goes forwards
                M569 P3 S0 ; physical drive 3 goes forwards,挤出机方向和位置
                M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1,两个Z电机链接到Z和E1
                M350 X128 Y128 Z128 E128 I0 ;不插值的细分
                M92 X800.00 Y800.00 Z5120 E3075 ; set steps per mm,脉冲数值
                M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min),突变速度
                M203 X6000 Y6000 Z120.00 E1200.00 ; set maximum speeds (mm/min),最大速度
                M201 X500.00 Y500.00 Z3.00 E250.00 ; set accelerations (mm/s^2),加速度
                M906 X1550 Y1500 Z1500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent,电机电流
                M84 S30 ; Set idle timeout,解锁等待
                M572 D0 S0.4 ;挤出提前值/延迟值,远程挤出配置
                M208 X-15 Y-30 Z0 S1 ; set axis minima
                M208 X310 Y300 Z400 S0 ; set axis maxima
                M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                ;M574 Z1 S1 P"!zstop+!e1stop" ; configure active-high endstops for low end on Z via pins zstop and e1stop,双Z双限位配置
                M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin zstop
                M591 P1 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop,断料检测
                ;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                ;G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                ;M558 P5 H5 I1 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                M557 X50:250 Y50:-300 S20 ; define mesh grid
                M501 ;PID校准保存
                M106 P0 C"模型风扇" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                M106 P1 C"LED灯" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                M106 P2 C"喉管风扇" S0.8 H-1 ; set fan 2 name and value. Thermostatic control is turned on
