    Solved RRF 3.2 on Duet Wifi -> failed to get file list
    Duet Web Control
    • Phil333
      Phil333 last edited by
      I am getting this error in my Duet Wifi 1.04c with RRF 3.2 and DWC 3.2.0 installed
      failed to get file list directory 0:/menu not found.
      I saw this thread:
      https://forum.duet3d.com/topic/12435/failed-to-get-file-list/10
      But its outdated, for a different hardware and I dont have a M918 in my config.
      I think I might need to add/delete some directorys/files onto the SD card, but I hope to get help, what that might be 😄
      If I have to to it, is it possible to do it from the DWC directly?
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jens55
        jens55 last edited by jens55
        I had that error come up after a long time of running without any errors. I ended up creating an empty file by the name of 'menu' and the problem went away. I think it was in the main 'sys' directory but can't verify at the moment.
        Edit: Yes you can make the file under DWC
        • jay_s_uk
          jay_s_uk @Phil333 last edited by
          @phil333
          You can either ignore it or create a folder called menu in the root of the SD card. It may be possible to do this over FTP but may be easiest just to pull the card and add it.
          Phil333 1 Reply Last reply Reply Quote 1
          • jay_s_uk
            jay_s_uk @jens55 last edited by
            @jens55 an empty file called menu won't fix this as its looking for a directory in the root of the SD card, not for a file in the sys folder
            jens55 1 Reply Last reply Reply Quote 1
            • jens55
              jens55 @jay_s_uk last edited by
              @jay_s_uk thanks I wasn't sure if it was in the 'sys' folder or the root directory and I couldn't check as my printer isn't connecting at the moment.
              It was a painless fix though. It was just confusing that one day the error message magically started appearing ....
              Phil333 1 Reply Last reply Reply Quote 0
              • Phil333
                Phil333 @jens55 last edited by
                @jens55
                Same to me. The error came by me only making a hardware change from thermocouple to thermistor (and of cause changing that only line in the config).
                Thanks @jay_s_uk I will do so and report back on tuesday 🙂
                • Phil333
                  Phil333 @jay_s_uk last edited by
                  @jay_s_uk
                  This solved the problem.
                  Thank you a lot 👍
