IDEX temperature control on U
409
  • undefined
    Seliv
    hi; )
    I have already managed to fully run two-color printing in IDEX, but I have one last problem, I think.
    I use Superslicer for this and I have a problem with changing the temperature from first layer to the next.
    The temperature only changes in X, but remains the same in U. Is it the fault of wrong settings in duet config or in superslicer? I don't know how to go about it now, or what can i change to solve it.
    thanks in advance for any guidance!
    • undefined
      Is Super Slicer aware of the different tools for X and U or is it sending just basic heating commands?
      • undefined
        Seliv
        From what I can see just basic heating commands.
        At the moment I made 2 profiles for filament and connected them to extruder 1 and 2 on printer . Theoretically this should do the job, but I see that when switching to T1 after the first layer there is no command to lower the temperature in gcode.
        I don't even know where to look for a solution.
        undefined 1 Reply Last reply 25 Apr 2021, 08:01 Reply Quote 0
        • undefined
          o_lampe @Seliv
          @seliv
          In PrusaSlicer, I can (have to) select two filament profiles. One for each extruder. They can be same. The big sister SuperSlicer doesn't have this option?
          undefined 1 Reply Last reply 25 Apr 2021, 10:20 Reply Quote 0
          • undefined
            Seliv @o_lampe
            @o_lampe
            Yes I have it too. 2 profiles for filaments. connected to First and second extruder, but only first X is working to change temp on next layers. 😕
            undefined 1 Reply Last reply 25 Apr 2021, 10:31 Reply Quote 0
            • undefined
              o_lampe @Seliv
              @seliv
              Do you have "M116 P1" in your tpost1.g?
              undefined 1 Reply Last reply 25 Apr 2021, 12:30 Reply Quote 0
              • undefined
                Seliv @o_lampe
                @o_lampe
                Yes I have it here
                • undefined
                  Seliv
                  It seems its SuperSlicer error. On prusa with the same config its working : >
                  1 out of 8
