M666 bed adjustment on a Delta
  • my bed rises slightly more the is compensated for in the calibration, so I wanted to try this. the difference is between the X and Z towers. the bed is a solid mount. if this were a standard printer I see this working out well. will this be adding more troubles for me being a Delta printer? and while I have your attention, on an old machine you had to delete the height map and config override when doing a new calibration. (it didn't overwrite the old one) Do I need to do that here or will the M500 overwrite properly for me where it needs to be?
    When you run auto calibration (G32), the height map loaded in memory (if any) is cleared automatically. You don't need to delete config-override.g. After running auto calibration, M500 will store the new parameters in config-override.g. Please note, config-override.g is only used if you have a M501 command near the end of config.g.
