    Internal Error in TaskLoop in Duet3-Mini SBC Mode only
    DSF Development
    383
    • poofjuniorundefined
      poofjunior
      Hey folks,
      I'm getting this error on the console when I try to home y. (Motors also energize but no movement happens.)
      Error: Internal Error in TaskLoop at ../src/Linux/LinuxInterface.cpp(104)
      My setup is:
      RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta3.2+1 running on Duet 3 Mini5plus Ethernet (SBC mode)
      (Duet 3 Mini, Raspi, and 3HC)
      I'll mention: before I was running in SBC mode, I was able to run the machine in standalone mode and home normally with identical configs (except for the network settings MCodes).
      My homey.g file is as follows:
      ; Home Y Axis
      ; In case homey.g is called in isolation, ensure
      ; (1) Endstop is not already triggered (in case of damaged endstop)
      ; Ask for user-intervention if any case fails.
      if sensors.endstops[1].triggered
        M291 "Cannot Home Y" P"Y Endstop is already triggered!" S2
        abort "Y Endstop was triggered before homing."
      G91                     ; Set relative mode
      G1 Y-400 F6000 H1       ; Big negative move to search for endstop
      G1 Y4 F600              ; Back off the endstop
      G1 Y-10 F600 H1         ; Find endstop again slowly
      G90                     ; Set absolute mode
      I'll mention that there's some logic above to behave differently if the endstops are already triggered, but they were untriggered when I was running it.
      Finally, the first few lines of
      apt-cache show duetsoftwareframework
      shows:
      Package: duetsoftwareframework
      Architecture: armhf
      Version: 3.2.2
      Priority: standard
      Section: electronics
      Maintainer: Duet3D Packaging Authority <pkg@duet3d.com>
      Depends: duetcontrolserver (= 3.2.2), duetsd (= 1.1.0), duettools (= 3.2.2), duetwebserver (= 3.2.2), duetwebcontrol (= 3.2.2), reprapfirmware (>= 3.2.2-1), reprapfirmware (<= 3.2.2-999)
      Filename: dists/stable/armv7/binary-armhf/duetsoftwareframework_3.2.2_armhf.deb
      Any thoughts would be most appreciated!
      • gloomyandyundefined
        gloomyandy @poofjunior
        @poofjunior Are you really running RRF 3.2-beta3.2+1? Any reason why you have not upgraded to 3.2.2?
        poofjuniorundefined 1 Reply Last reply Reply Quote 0
          It looks like your firmware versions are out of whack. You've got 3.2beta2+1 on the board, but DSF 3.2.2 on the Pi.
          How are you doing your updates? What version are you wanting to run?
            poofjunior @gloomyandy
            @gloomyandy huh; that output was after I ran
            sudo apt update
            sudo apt upgrade
            Do I still need to plop the firmware into the Duet 3 Mini Web Interface, or does the duetsoftwareframework package not do this for you?
              It can get a little out of whack when using beta version that haven't been installed from the unstable branch on the Pi. I suggest you upload the 3.2.2 zip file to the mini via DWC. If that doesn't prompt for a firmware update, then send M997 to initiate it.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
              That should get you back in sync with 3.2.2.
                poofjunior @Phaedrux
                @phaedrux Yup that did it! Uploading the zip and installing the latest firmware fixed it.
                Cheers--and thanks for mentioning that I was behind!
                  3.3 final should be out soon hopefully and then you'll be able to update with the normal sudo apt update commands.
                    @phaedrux I am very excited for it! Thanks for the heads-up.
