Homing issue! Help!
Firmware installation
434
  • undefined
    Robbe21
    Hello guys! I have a Problem with my Printer, when i home the X-Axis it works fine, after it i home Y-Axis and it cant stop homing, it like an endless loop.
    Same Problem in reverse Order!
    I dont know what i´ve done wrong:/
    Video
    Thanks!
    undefined 1 Reply Last reply 28 Apr 2021, 09:33 Reply Quote 0
    • undefined
      felek @Robbe21
      @robbe21 Hi!
      We need your config.g and home#.g files
      undefined 1 Reply Last reply 28 Apr 2021, 09:50 Reply Quote 0
      • undefined
        Robbe21 @felek
        @felek Oh i forgot that!:D
        homeall.g
        config.g
        homez.g
        homey.g
        homex.g
        undefined 1 Reply Last reply 28 Apr 2021, 11:24 Reply Quote 0
        • undefined
          felek @Robbe21
          @robbe21
          Do you get any error/warning in DWC Console?
          undefined 1 Reply Last reply 28 Apr 2021, 12:23 Reply Quote 0
          • undefined
            Robbe21 @felek
            @felek Nope there is nothing. Just when i power it up the Status in the Webinterface is busy.
            undefined 1 Reply Last reply 28 Apr 2021, 12:30 Reply Quote 0
            • undefined
              felek @Robbe21
              @robbe21
              Did you try to replace endstop?
              While homing Y axis try to put M122 in DWC console and put here output
              undefined 1 Reply Last reply 28 Apr 2021, 20:44 Reply Quote 0
              • undefined
                Robbe21 @felek
                @felek
                If i execute the M122 Command in the Console this happens:
                I lost the connection to the Duet Webcontrol and the DIAG LED on the Duet was permanetly blinking.
                undefined 1 Reply Last reply 28 Apr 2021, 20:45 Reply Quote 0
                • undefined
                  Robbe21 @Robbe21
                  @robbe21 I didnt tried to replace the Endstop, i think the Endstop works, because when i home Y-Axis before the X-Axis it works.
                  undefined 1 Reply Last reply 28 Apr 2021, 20:54 Reply Quote 0
                  • undefined
                    felek @Robbe21
                    @robbe21 Ok, that's weird.
                    Can you post M122 anyway?
                    undefined 1 Reply Last reply 28 Apr 2021, 22:00 Reply Quote 0
                    • undefined
                      Robbe21 @felek
                      @felek M122
                      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                      Board ID: 08DJM-956BA-NA3TN-6JTDG-3SD6K-TABQT
                      Used output buffers: 1 of 40 (10 max)
                      Static ram: 154604
                      Dynamic ram: 162580 of which 56 recycled
                      Exception stack ram used: 224
                      Never used ram: 75752
                      Tasks: NETWORK(ready,1980) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                      Owned mutexes:
                      Last reset 00:00:56 ago, cause: power up
                      Last software reset at 2021-04-28 10:58, reason: User, spinning module LinuxInterface, available RAM 75212 bytes (slot 1)
                      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                      Error status: 0
                      MCU temperature: min 22.7, current 26.2, max 26.2
                      Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                      Driver 0: standstill, reads 12480, writes 14 timeouts 0, SG min/max 0/0
                      Driver 1: standstill, reads 12480, writes 14 timeouts 0, SG min/max 0/0
                      Driver 2: standstill, reads 12481, writes 14 timeouts 0, SG min/max 0/0
                      Driver 3: standstill, reads 12481, writes 14 timeouts 0, SG min/max 0/0
                      Driver 4: standstill, reads 12485, writes 11 timeouts 0, SG min/max 0/0
                      Driver 5: standstill, reads 12485, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2021-04-28 23:58:35
                      Slowest loop: 3.92ms; fastest: 0.14ms
                      === Storage ===
                      Free file entries: 10
                      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP* is ready with "M122" in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger* is idle in state(s) 0 0, running macro
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon* is idle in state(s) 0
                      Aux2 is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 1.45ms; fastest: 0.01ms
                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                      HTTP sessions: 0 of 8
                      • Ethernet -
                        State: disabled
                        Error counts: 0 0 0 0 0
                        === CAN ===
                        Messages sent 129, longest wait 0ms for type 0
                        === Linux interface ===
                        State: 0, failed transfers: 1
                        Last transfer: 16ms ago
                        RX/TX seq numbers: 1340/1341
                        SPI underruns 1, overruns 1
                        Number of disconnects: 0
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v3.2.2
                        Trigger:
                        Buffered code: M501 ; load saved parameters from non-volatile memory
                        ==> 24 bytes
                        Executing macro config.g, started by system
                      Next stack level
                      Pending code: M905 P"2021-04-29" S"00:00:12"
                      Code buffer space: 4096
                      Configured SPI speed: 8000000 Hz
                      Full transfers per second: 9.94
                      Maximum length of RX/TX data transfers: 3168/728
                      undefined 1 Reply Last reply 28 Apr 2021, 22:50 Reply Quote 0
                      • undefined
                        Phaedrux Moderator @Robbe21
                        @robbe21 said in Homing issue! Help!:
                        It looks like your installed duet firmware doesn't match the duet software installed on the pi.
                        Please try sending M997 on the Duet console to initiate a firmware update. Afterwards check the version with M115. If it's still on 3.1.1 please upload this zip file to the system tab and send M997 again if it doesn't automatically update.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                        Afterwards you should be able to stay in sync with future updates by sending sudo apt update and sudo apt upgrade on the SBC.
                        The only problem I see with your config and homing files is that you are using a Z1 H1 endstiop homing move but don't have a Z endstop defined.
                        G1 H1 Z-325 F360 ; move Z down stopping at the endstop
                        G90 ; absolute positioning
                        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                        M574 X1 S1 P"^io0.in" ; configure active-high endstop for low end on X via pin ^io0.in
                        M574 Y1 S1 P"^io1.in" ; configure active-high endstop for low end on Y via pin ^io1.in
                        To use the probe you need to replace those lines in homeall.g with a G1 X Y move to position the probe and then a G30 to use it.
                        undefined 1 Reply Last reply 29 Apr 2021, 07:47 Reply Quote 1
                        • undefined
                          Robbe21 @Phaedrux
                          Thank you guys! It finaly works! Nice Support!
                          2 out of 12
