    Is there a way to debug accelerometer connection issues?
    Beta Firmware
    2.2k
    • OwenDundefined
      OwenD
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta3 (2021-04-22)
      I've got a couple of accelerometers and believe I've carefully followed the connection instructions, but I can't get RRF to recognize the accelerometer.
      I've done a continuity test on all connections and I'm using about 400mm of shielded 9 core cable.
      However I get the following error
      Is there any way of further debugging the issue?
      I've tried both accelerometers.
      Here is my wiring
      Here is config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sat Jan 04 2020 09:46:45 GMT+1000 (Australian Eastern Standard Time)
      ; serial comms / Paneldue
      M575 P1 B57600 S1
      G90                                                         ; send absolute coordinates...
      M83                                                         ; ...but relative extruder moves
      M550 P"3Dprinter"                                       	; set printer name
      M554 P192.168.1.1											; set gateway
      M553 P255.255.255.0											; set netmask
      M552 S1 P"DARE"                                             ; enable network
      M586 P0 S1                                                  ; enable HTTP
      M586 P1 S1                                                  ; enable FTP
      M586 P2 S1                                                  ; enable Telnet
      M569 P0 S1                                                  ; physical drive 0 (X) goes forwards
      M569 P1 S0                                                  ; physical drive 1 (Y) goes backwards
      M569 P2 S1                                                  ; physical drive 2 (Z) goes forwards
      M569 P3 S0                                                  ; physical drive 3 (E0) goes backwards
      M584 X0 Y1 Z2:4 E3											; two Z motors connected to driver outputs Z and E1
      M671 X-74:240 Y79:79 S5.5 									; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M350 X16 Y16 Z16 I1                           				; Configure microstepping with interpolation for XYZ
      M350 E16 I1													; Configure microstepping with interpolation for E0
      M92 X100.00 Y100.00 Z400.00                            		; set steps per mm XYZ
      M92 E854										; set E steps/mm for Titan Aero
      ; axis settings
      M98 P"0:/sys/set_max_speeds.g" ; set all the max speeds in macro as these are adjusted during home moves so we only want to adjust in one spot
      M906 X1100 Y1100 Z1100 E1400 I30                             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                     ; Set idle timeout
      M208 X0:215 Y0:198 Z0:180 									; X carriage moves from 0 to 200, Y bed goes from 0 to 198
      M574 X1 S1 P"xstop"                                         ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                         ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                                  ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                                      ; create servo pin 0 for BLTouch
      ;M558 P9 C"^zprobe.in" H6 F180:60 T2400 A10 S0.03 R0.5 B0         ; set Z probe type to bltouch and the dive height + speeds
      M558 P9 C"^zprobe.in" H6 F600:180 T2400 A10 S0.03 R0.5 B0         ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X27 Y-2 Z0.48                                  	; set Z probe trigger value, offset and trigger height
      M557 X30:200 Y10:180 S30                                    ; define mesh grid
      ;Calculate bed centre
      ;global Bed_Center_X =move.compensation.probeGrid.maxs[0]-move.compensation.probeGrid.mins[0])/2) + move.compensation.probeGrid.mins[0] - sensors.probes[0].offsets[0]
      ;global Bed_Center_Y = (move.compensation.probeGrid.maxs[1]-move.compensation.probeGrid.mins[1])/2) + move.compensation.probeGrid.mins[y] - sensors.probes[0].offsets[1]
      M308 S0 P"bedtemp" Y"thermistor" A"Bed" B3950 C7.06e-8         		; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0 Q10                                       ; create bed heater output on bedheat and map it to sensor 0 and set PWM frequency to 10hz
      M140 H0 																		; Set bed themp to zero
      M143 H0 S130 A0 C0                                          ; set temperature limit for heater 0 to 130C - fault if too high
      M308 S1 P"e0temp" Y"thermistor" A"Nozzle-1" B4725 C7.06e-8          		; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                        ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S285 A0 C0                                          ; set temperature limit for heater 1 to 280C - fault if too high
      ;echo "sensor create time: " ^ state.upTime ^ "." ^ state.msUpTime
      ; Set PID autotune parameters
      M307 H0 R0.553 C379.7 D21.16 S0.80 B0 V0
      M307 H1 B0 R1.594 C358.1:217.5 D6.05 S1.00 V24.3			;set PID values for heater 1 (hotend)
      ; Joystick
      M308 S3 P"exp.thermistor4" Y"linear-analog" A"JoyStick-X" F1 B100 C-100 ; set analog input on E3 Temp with min/max of -100 to 100
      M308 S4 P"exp.thermistor6" Y"linear-analog" A"JoyStick-Y" F1 B100 C-100 ; set analog input on E5 Temp with min/max of -100 to 100
      M581 T7 P7 ; set up trigger for GpIn 7
      M950 J7 C"!^exp.31" 										; Input 7 uses Expansion 31 pin activate pullup and inverted
      ; Servos and input/output
      M950 P5 C"exp.e5_stop" 										; Output 5 uses E5_STOP  pin
      M950 J6 C"exp.e6_stop" 										; Input 6 uses E6_STOP  pin
      ; Filament monitor
      M591 P1 C"e0stop" S1  D0 									; filament monitor for extruder 0 connected to E0 endstop
      M950 F0 C"fan0" Q50                                        ; create fan 0 on pin fan0 and set its frequency
      M106 P0 C"Part_Fan" S0 B2.0 H-1                             ; set fan 0 name and value. Thermostatic control is turned off
      																; Adjust MCU temp reading to match ambient
      ;water pump
      M950 F1 C"!fan1+^exp.pb6" Q25000                             ; create fan 1 (water pump) on inverted pin fan1 and set its frequency.  Set RPM to E3 stop with pullup enabled
      M106 P1 C"Water Pump" H1 L0.5 X1 B1.2  T50:60                       ; set fan 1 name and value. Thermostatic control is turned on.  Monitoring hoted sensor
      ; water temp monitor & fan
      M950 F2 C"!fan2+^exp.e3_stop" Q25000                                        ; create fan 2 on pin fan2 and set its frequency
      M308 S5 P"e1temp" Y"thermistor" A"Water temp" T10000 B3950  					; Configure Water temp sensor
      M106 P2 C"Radiator Fan" H5 L0 X1 B1.2  T33:38    	; set fan 4 value, turn on at 30% if the water temperature reaches 30C, and increase to full speed gradually as the temperature rises to 40C
      ; MCU temp sensor
      M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" 					; Configure MCU sensor
      ; Calibrate MCU temp
      M912 P0 S-4
      M563 P0 S"Extruder1" D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                             ; set tool 0 axis offsets
      G10 P0 R0 S0  ; set initial tool 0 active and standby temperatures to 0C
      ; Global Variables for heater checking routine in daemon.g
      while heat.heaters[1].current = 2000 ; loop until thermistor values are stable
      	G4 P1
      	if iterations > 10000 ; if it takes more than 10 seconds we have a problem with the thermistor
      		M118 P0 L1 S"Thermistor failed to stabilize in less than 10 seconds"
      		break
      ;echo "sensor stable time: " ^ state.upTime ^ "." ^ state.msUpTime
      if !exists(global.LastTemp)
      	global LastTemp = heat.heaters[1].current ; Set variable to current extruder temp.
      else
      	set global.LastTemp = heat.heaters[1].current ; Set variable to current extruder temp.
      if !exists(global.LastCheckTime)
      	global LastCheckTime = 0 ; variable for use in daemon.g
      else
      	set global.LastCheckTime = 0 ; variable for use in daemon.g
      ;Select tool zero
      T0 P0
      ; extrusion
      if !exists(global.LoadedFilament) ; global variable to hold filament name
      	global LoadedFilament = "No_Filament" ; create a filament variable
      if move.extruders[state.currentTool].filament=""
      	echo "No filament loaded.  Cold extrude & retract set to defaults"
      	M302 S190 R110 ; Allow extrusion starting from 190°C and retractions already from 110°C (defaults)
      	set global.LoadedFilament = "No_Filament"
      else
      	set global.LoadedFilament = move.extruders[state.currentTool].filament ; set the variable to the currently loaded filament
      	echo "Loading config for " ^ global.LoadedFilament ^ " filament"
      	M703 ; if a filament is loaded, set all the heats and speeds for it by loading config.g
      ; Custom settings
      M376 H4   ; set bed compensation taper (H4 means taper over 4mm)
      ; Power failure recovery
      M911 S22.5 R23.0 P"M42 P5 S0 M106 P0 S0 M913 X0 Y0 G91 M83 G1 Z3 E-2 F1000" ; If power drops below 22v then turn off fans, Set X & Y current to zero, raise head, retract.
      ; turn on LED strip driven by P5 output
      M42 P5 S1
      ;Valve Control test to control servo position via fan speed
      ; Set up scaling variables {(output_end - output_start) / (input_end - input_start)}
      ;M950 S1 C"exp.heater4"  ; assign GPIO port 0 to heater4 on expansion connector, servo mode
      if !exists(global.InputStart)
      	global InputStart = 0
      if !exists(global.InputEnd)
      	global InputEnd = 1
      if !exists(global.OutputStart)
      	global OutputStart = 0
      if !exists(global.OutputEnd)
      	global OutputEnd = 180
      if !exists(global.ScaleFactor)
      	global ScaleFactor = (global.OutputEnd - global.OutputStart) / (global.InputEnd - global.InputStart) ; no need for the math in this instance but it makes it clear how you arrive at the value.
      if !exists(global.ServoOut)
      	global ServoOut = floor(global.ScaleFactor * (fans[0].actualValue - global.InputStart) + 0.5) + global.OutputStart ; calculate position required on sevo - use floor() to apply rounding
      ;M280 P1 S{global.servo_out} ; adjust valve position to reflect fan speed.
      ;play startup tune
      G4 S8					; Allow time for PanelDue to start & wifi connection etc
      M98 P"0:/macros/songs/itchyscratchy.g"								; Play tune
      M501 ; load config-overide.g
      ; configure accelerometer
      M955 P0 C"spi.cs3+spi.cs4" ; configure accelerometer
      • OwenDundefined
        OwenD
        I've now tried the cable on an Arduino and it works.
        The only difference is that arduino doesn't use INT pin
          dc42 administrators @OwenD
          If the INT pin is not connected then the accelerometer will still be detected, but collecting data won't work.
          What SPI clock rate did you use when testing it with the Arduino? Duet uses 4MHz.
          In your photos, the VIN pin of the sensor breakout board does not appear to be connected, so the board will not receive power in the correct manner (unless there is another VIN pin on the other side).
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @dc42
            @dc42 said in Is there a way to debug accelerometer connection issues?:
            I don't rightly know.
            I just followed this tutorial and set it for software SPI.
            https://learn.adafruit.com/adafruit-lis3dh-triple-axis-accelerometer-breakout/arduino
            I was able to get data from both the acceldemo and tap demo.
            VIN is connected (red wire) , it's just that I only had 4pin housings so it's just a single wire straight onto the header pin.
            It's a bit hard to see in the photo.
            The LED on the breakout board lights up indicating it's powered up.
              OK, I see the pin connection now. Is that the newer version of the Adafruit board? What is the pin between GND and SDA (white wire)?
              dc42undefined SIamundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @dc42
                PS - you initially had this according to the error message:
                M955 P0 C"spi.cs4+spi.cs3" ; configure accelerometer
                but your config.g has this:
                Which are you using? I think spi.cs3+spi.cs4 is correct for your wiring scheme.
                • SIamundefined
                  SIam @dc42
                  @dc42 the white wire is the SCL pin
                  Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                  Duet WiFi 1.02 or later + DueX5
                  RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                  Duet WiFi Server: 1.26
                  Duet Web Control 3.4.0beta4 (2021-09-27)
                  • OwenDundefined
                    OwenD @dc42
                    I had originally tried M955 P0 C"spi.cs3+spi.cs4" per my config.
                    When I was running out of ideas, I tried reversing it. I must have picked up the error message from the latter.
                    This breakout board has QT connections available. Otherwise it's identical.
                    OK, I see the pin connection now. Is that the newer version of the Adafruit board? What >is the pin between GND and SDA (white wire)?
                    The pin between VIN and GND says 3V. I had been using VIN, but as that would be 5V on the arduino and 3V on the duet, I just tried again using the 3V pin.
                    Same result. Unit powers up, but is not found.
                    Data sheet
                    https://cdn-learn.adafruit.com/assets/assets/000/085/846/original/lis3dh.pdf?1576396666
                    Schematic
                    https://learn.adafruit.com/assets/94435
                    The data sheet says that the CS pin must be brought low to enable SPI and it defaults to I2C
                    Could this be the issue?
                      Have you tried using a different Duet pin to connect CS to? E.g. spi.cs1
                      • OwenDundefined
                        OwenD @dc42
                        Just tried it.
                        Moved green wire (CS) to spi.cs1
                        Same result.
                        On a side note, there seem to be two wiring diagrams floating around.
                        One says it's CS1 and the other CS0
                        https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/JPWtqVWwLBxCAKyP.huge
                        https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/vqBUAZPsxMC5tRgt.huge
                        The one that says CS0 can be found here
                        https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet+2+WiFi-Ethernet/9
                        • OwenDundefined
                          OwenD
                          OK.
                          I just tried wiring directly to the LIS3DH using 150mm jumpers and it works!
                          Strange that the other cable works on an arduino.
                          Would it be better to use cable that has twisted pairs?
                          I thought the shielded cable would be a good option.
                          Diamondbackundefined 1 Reply Last reply Reply Quote 0
                          • Diamondbackundefined
                            Diamondback @OwenD
                            @owend What kind of cable are you using? Another user and I had good success with USB 3 cables (mine is 3m long).
                            OwenDundefined tekstyleundefined 2 Replies Last reply Reply Quote 0
                            • OwenDundefined
                              OwenD @Diamondback
                              @diamondback
                              I was using 9 core shielded
                              https://www.altronics.com.au/p/w2712-9-core-shielded-data-cable/
                              I'm about to try some CAT5 data cable (4 x twisted pairs)
                              I'll report back.
                                Diamondback @OwenD
                                @owend Ok, I tried single twisted pairs first, ie basically the inner part of CAT 5 cable without any shielding, and that didn't work for me. The USB cable is both twisted and shielded multiple times, I connected all the shielding to GND as well.
                                • OwenDundefined
                                  OwenD
                                  Success!
                                  For me a piece pf CAT5E cable worked.
                                  I'm reasonable confident the connections on the first cable are sound.
                                  Perhaps a better choice would be the USB cables suggested or maybe CAT6 shielded cables?
                                  Now I have some data...
                                  Just have to work out what to do with it 🙄
                                  Diamondbackundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                    Diamondback @OwenD
                                    @owend said in Is there a way to debug accelerometer connection issues?:
                                    Success!
                                    Awesome! 👏
                                    • zaptaundefined
                                      zapta @OwenD
                                      An oscilloscope would allow you to look at the signals and see if they are missing or distorted.
                                      • OwenDundefined
                                        OwenD @zapta
                                        @zapta said in Is there a way to debug accelerometer connection issues?:
                                        True. But out of the reach of many of us.
                                        In my original post topic I was hoping that RRF could somehow self diagnose communication on each pin.
                                        It seems like it's going to be pretty critical to get cables just right for this to work.
                                        zaptaundefined 1 Reply Last reply Reply Quote 0
                                        • zaptaundefined
                                          zapta @OwenD
                                          That's correct. Digital oscilloscope prices went down very significantly but it's still a significant amount of money.
                                          Let's see if future generations of Duet boards will have an accelerometer connector that will work out of the box with the optional Duetcelerometer module. 😉
                                            dc42 administrators @zapta
                                            I have made the accelerometer SPI clock frequency configurable and reduced the default from 4MHz to 2MHz. I expect this will make it easier to obtain a connection. These changes will be in RRF 3.3RC1.
