Solved [3.3-rc1] homing causes controller reset
Simple test at the moment using 3.3-rc1. Printer was working under 3.3b3.
Power the controller and SBC up from the mains
Try to home X by either hitting the home X button in DWC or typing G28 X into the DWC command sender.Board powers up but does not move any motors.
I have this homex.g
M98 P"/macros/poweron.g" M913 X30 G91 G1 H1 X-550 F20000 ; coarse home X G1 X20 F20000 ; move away from the endstops G1 H1 X-20 F1000 ; fine home X G90 M913 X100 G53 G1 X{-sensors.probes[0].offsets[0]} F20000
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3RC1 (2021-05-01 09:12:50) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D8-3S86J-9B36F Used output buffers: 1 of 40 (10 max) === RTOS === Static ram: 150680 Dynamic ram: 62924 of which 0 recycled Never used RAM 140588, free system stack 208 words Tasks: SENSORS(delaying,0.0%,80) SBC(ready,5.7%,321) HEAT(delaying,0.0%,337) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,343) TMC(notifyWait,0.0%,105) MAIN(running,93.9%,924) IDLE(ready,0.4%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:00:33 ago, cause: software Last software reset at 2021-05-01 18:10, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 140588, slot 2 Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000004 SP 0x2041af48 Task MAIN Freestk 1521 ok Stack: 2042b2b4 2042b334 2042b348 00000000 20424c20 00455f33 0044b182 81070000 00499e60 2042b434 00000000 00000000 00000000 20423f20 00000001 00000000 2041b0f0 ffffffed 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Step timer max interval 736 MCU temperature: min 42.9, current 43.0, max 43.3 Supply voltage: min 0.2, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, power good: no 12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0 Date/time: 2021-05-01 18:11:03 Slowest loop: 1.10ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0 sensor: ok === CAN === Messages queued 297, send timeouts 295, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49) Last cancelled message type 30 dest 127 === SBC interface === State: 1, failed transfers: 0 Last transfer: 0ms ago RX/TX seq numbers: 3484/1190 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c90c Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.3-rc1 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 21.10 Codes per second: 0.70 Maximum length of RX/TX data transfers: 3444/932
config.g
i@hevort:/opt/dsf/sd/sys $ cat config.g M550 P"hevort" ; set machine label M584 X0.3 Y0.4 Z0.0:0.1:0.2 E0.5 ; Assign drivers to axes M669 K1 ; Set system to CoreXY M569 P0 S0 D2 ;H0 ; Reverse Z1 motor direction M569 P1 S0 D2 ;H0 ; Reverse Z2 motor direction M569 P2 S0 D2 ;H0 ; Reverse Z3 motor direction M569 P3 S0 D2 ;H0 ; Reverse X motor direction M569 P4 S0 D2 ;H0 ; Reverse Y motor direction M569 P5 S0 D2 ;H0 ; Extruder motor setup, reverse direction M671 X-31:546:257 Y0:0:546 S100 ; Set Z probe points M574 X1 S1 P"io1.in" ; Configure X endstop M574 Y1 S1 P"io2.in" ; Configure Y endstop M574 Z2 S4 ; Use stallguard for Z1 endstop for max Z. Allow each motor to stall independently M915 X S3 F0 R1 ; Configure stallguard detection for X M915 Y S3 F0 R1 ; Configure stallguard detection for Y M915 Z S1 H400 F1 R1 ; Configure stallguard detection for Z M915 E S3 F0 R1 ; Configure stallguard detection for E M906 X1500 Y1500 Z1500 E1000 I80 ; Motor currents in ma + idle percentage M92 X80 Y80 E400 Z800 ; Steps per mm M203 Z2500 Y100000 X100000 ; Max feedrate in mm/min M201 X1000.0 Y1000.0 Z50.0 E250.0 ; Max acceleration mm/sec^2 M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; Set up bed thermistor M950 H0 C"out0" T0 Q10 ; Set up bed heater output M140 P0 H0 ; Configure bed heater M307 H0 A110.3 C221.0 D3.9 V24.0 B0 ; Configure bed heating process parameters M304 P91.5 I3.111 D250.3 ; Configure bed heating PID parameters M308 S1 P"temp1" Y"thermistor" A"Hotend" T100000 ; B3950 ; Set up hotend thermistor M950 H1 C"out1" T1 ; Set up hotend heater M563 P0 S"Volcano" D0.5 H1 F2; Create new tool for hotend using air pump M143 H1 S300 A3 ; Set max heater temp to 300C G10 P0 X0 Y0 Z0 R0 S200 ; Set default tool temperatures and offsets ;M307 H1 A838.7 C467.3 D8.3 V23.9 B0 ; Hotend pid parameters ;M307 H1 R1.612 C384.3 D10.70 S1.00 V24.0 ; PID Parameters Volcano, 220C M307 H1 R1.752 C200.1 D8.36 S1.00 V24.0 ; PID Parameters Volcano, 220C + full berd air M308 S10 P"spi.cs0" Y"dht22" A"Enclosure Temp" ; Set AM2302/DHT22 pin M308 S11 P"S10.1" Y"dhthumidity" A"Enclosure Humidity" ; Set AM2302/DHT22 humidity subsensor M950 S2 C"io4.out" ; Bltouch servo pin M558 C"^io4.in" H20 F600 T6000 P9 ; Configure z probe, Bltouch M280 P2 S160 ; Reset BLTouch G31 P500 X12 Y-27 Z2.733 ; set Z probe trigger value, offset and trigger height M950 C"out2" F0 ; First fan = Water pump can add tacho input later M106 P0 S255 T50 C"Water pump" H1 ; Set Fan0 to be thermostatically controlled against hotend temp > 50C M950 C"out4+out4.tach" F1 ; Second fan = radiator fan M106 P1 S255 T50 H1 C"Radiator fan" M950 C"out3" F2 Q30000 ; Third fan = air pump M106 P2 C"Air pump" M950 C"out9" F3 Q30000 ; Enclosure LED M106 P3 C"Lights" S255 M950 C"!out5" F4 ; HEVACS inverted PWM M106 P4 C"HEVACS" M591 D0 P1 C"^io0.in" S1 ; Filament runout sensor M208 X-265.7 Y-260 Z0 S1 ; Set axes minima M208 X249.3 Y245 Z470 ; Set axes maxima M557 X-250:249.3 Y-262.7:232 S25 ; Set probe grid limits M572 D0 S0.025 ; Pressure advance M207 P0 S0.2 F2400 ; Retraction 0.2mm at 40mm/s
M98 P"/sys/config.g" returns no output.
@serbitar said in [3.3-rc1] homing causes controller reset:
I'm getting the same issue.
Does yours give this error after the connection is lost when trying to home?Lost connection to Duet (Board is not available (no header))
@Serbitar and @tristanryerparke, thanks for the report. I have located the problem and I am preparing a fix.
@serbitar and @tristanryerparke please try the new 3.3RC1+1 firmware binary at https://www.dropbox.com/sh/dlb58vkmu1u4fkx/AAAelkXSfRKVwI6_yqRnhGHPa?dl=0 and let us know whether it resolves the problem.
@dc42 That's fixed it!
Thanks for turning the fix around so quickly
@dc42 You saved the day again david, back up and running no issues so far.
Thanks,
T -
That fixed it for me as well.
