    Tevo little monster
    Firmware installation
    466
    • TRIPZ2757
      TRIPZ2757 last edited by
      hey im new to this but i wanted to ask if anyone can help me set up my bored cant get it too run can someone please help me im at a freash new start
      • peirof
        peirof last edited by
        @tripz2757 said in Tevo little monster:
        ant get it to
        i have a TLM modded with Duet... in what can i help you?
        TRIPZ2757 2 Replies Last reply Reply Quote 1
        • TRIPZ2757
          TRIPZ2757 @peirof last edited by
          @peirof
          hey you think you can share your config.g file
          • TRIPZ2757
            @peirof
            everything i try seems to not work when i home it starts and then just keeps on going and going and havent been able to do anything with it
              Phaedrux Moderator @TRIPZ2757 last edited by
              @tripz2757 You could post your files as well and maybe we can spot what's wrong. We'd need to see config.g, homedelta.g, bed.g.
              Have you gone through these?
              https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
              https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
              TRIPZ2757 Phaedrux 2 Replies Last reply Reply Quote 0
              • TRIPZ2757
                TRIPZ2757 @Phaedrux last edited by
                @phaedrux
                config.json
                thats my config file
                  can you post the actual config.g please? The .json files are intended for computers to read back the data.
                  TRIPZ2757 1 Reply Last reply Reply Quote 0
                  • TRIPZ2757
                    @phaedrux
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon May 03 2021 10:47:43 GMT-0700 (Pacific Daylight Time)
                    M550 P"TEVO MY LITTLE MONSTER" ; set printer name
                    M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S1 ; enable FTP
                    M586 P2 S1 ; enable Telnet
                    M92 X80.00 Y80.00 Z80.00 E798 ; set steps per mm
                    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000 E1200 ; set maximum speeds (mm/min)
                    M201 X1000 Y1000 Z1000 E1000 ; set accelerations (mm/s^2)
                    M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 Z0 S1 ; Set minimum Z
                    M574 X2 Y2 Z2 S1 ; Set active high endstops
                    M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
                    M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                    G31 P25 X0 Y20 Z0.2 ; Set Z probe trigger value, offset and trigger height
                    M557 R150 S45 ; Define mesh grid
                    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                    ; Custom settings
                    M591 D0 C3 P2 E6.0
                      Phaedrux Moderator @Phaedrux last edited by Phaedrux
                      @phaedrux said in Tevo little monster:
                      How bout your other delta related files? Maybe config-override.g as well so we can see your saved delta calibration results?
                      And maybe the results of M122 so we can see your firmware version etc.
