    Error: Temp reading fault on heater 1: unknown sensor 3.3rc1+1
    Beta Firmware
    557
    • appjawsundefined
      appjaws
      I have installed a PT100 Daughterboard and a PT100 sensor but I am getting the following error:-
      Error: Temperature reading fault on heater 1: unknown sensor
      This is the config entries:-
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
      M950 H1 C"spi.cs1" T1 ; create nozzle heater output on e0heat and map it to sensor 1
      Perhaps I have misunderstood the instructions, do I need any other config entries?
      jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @appjaws
        @appjaws there's RC1+1 available here https://forum.duet3d.com/topic/23025/software-package-3-3-rc1-released/2
        Please upgrade to that
        • appjawsundefined
          appjaws
          Updated firmware but still have the same error.
            Phaedrux Moderator @appjaws
            @appjaws Can you confirm firmware version with M115?
            appjawsundefined 1 Reply Last reply Reply Quote 0
            • appjawsundefined
              appjaws @Phaedrux
              @phaedrux
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3RC1+1 ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2021-05-01 21:43:27
                Thanks for confirming.
                • appjawsundefined
                  appjaws @Phaedrux
                  @phaedrux Do you think I have the correct entries in config.g?
                  Just to let you know, I also have installed an accelerometer:
                  ; configure accelerometer
                  M955 P0 C"spi.cs3+spi.cs4" ; configure accelerometer
                    @appjaws said in Error: Temp reading fault on heater 1: unknown sensor 3.3rc1+1:
                    Actually, no.
                    Where do you have the heater physically connected?
                    M308 S1 P"spi.cs1" Y"rtd-max31865"             ; configure sensor 1 as thermocouple via CS pin spi.cs1
                    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                    Should be e0heat rather than an spi pin. The SPI is for the temp sensor. The M950 needs to be the heater itself.
                    • appjawsundefined
                      appjaws @Phaedrux
                      @phaedrux
                      Really strange, that is what I had at first and in trying to solve the problem ended up with the wrong code.
                      I can now report that I have an ambient temperature reported.
                      Thanks for your help.
                        Glad it was something simple. 😉
                        • appjawsundefined
                          appjaws @Phaedrux
                          This post is deleted!
