Cad file?
Does anyone have an accurate cad mockup of the effector? I'm looking to start designing some fan shrouds and such and having a 3d file of it accurately sized and with the proper holes that I could fly into fusion and start working off of would save me some time! Let me know! Thanks!
Stefan Giudici
I made a start on the effector plate last week, Im hoping that I have the holes in accurate locations. Heres a link to the file in Fusion 360 if you want use it - http://a360.co/2vQXDqm
Awesome, do you happen to know if the thickness is correct? The other proportions are good? I'm gonna do some mockups of it with the hotend attached and give us a good baseline for what this looks like in its final state so people can work on custom mods/fans etc. I'm pretty busy at the moment but when things slow down if I make any progress with it I'll share everything publicly.
The thickness was an approximation so that I could extrude it to use it in the drawing module. I can measure mine when I get in and adjust it.
The PCB thickness is 1.6mm
Thanks, I updated the fusion file. There's also a file for the carriage.
Effector Plate - http://a360.co/2vQXDqm
Carriage - http://a360.co/2v1NnwE
carriages are 2mm thick
lol. Carriages updated.
would be great to add the custom heatsink, for fan mount design purpose.
is there any blueprint somewhere ? more specifically for the head of the heatsink, since the core is standard. something like this : http://files.e3d-online.com/v6/Drawings/V6-175-SINK.pdf
I just used the standard e3d model on thingiverse, measured how far down from the bottom of the effector the new heatsink ends, and set the standard model that far through the model. Works well enough.
E3D is going to make this heatsink variant a standard stock item except that they intend to change the thread pitch from 1mm to 1.25mm. So I suggest you ask them.
FYI : space between PCB and heatsink body -> 2mm
Carriage - http://a360.co/2v1NnwEthanks again for your models, for now they seems to fit quite well ! next step adding connector and components maybe ?
