    Duet 3 drivers quit working
    Using Duet Controllers
    154
    • jgassett
      jgassett last edited by
      Hi.
      I am relatively new to 3D printing, but have some experience with building and operating lead screw driven open-source CNC machines. In the last month, I built my first 3D printer with a Duet 3 controller. The printer build and setup went smoothly, as did the calibration steps. For about a week, the printer worked fine, printing multiple, simple jobs each day. About a week after it was fully operational, it was in the middle of a print job and suddenly quit with multiple faults showing on several drivers. Unfortunately, I didn't capture those errors before they were gone. When I began troubleshooting, it became apparent that Drivers 0 and 1 were still operational, while drivers 2-5 were non-functional. I tested all 4 of my steppers on each of the drivers to verify this as well as to verify that it was not a wiring/connection issue. At the time of failure, only Drivers 0, 1, 2, and 3 were in use - Drivers 4 and 5 were disconnected. When I run an M122 Diagnostic, I can't see any errors associated with any of the Drivers, although I admit that I only know what I have read on this forum. So I need help! Anyone have any suggestions for how to move forward? I emailed MatterHackers (where it was purchased) and they suggested I post the situation here to hopefully find a fix or get the board replaced under warranty.
      The Config.g file is here:
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 20 2021 13:19:17 GMT-0400 (EDT)
      G90
      M83
      M550 P"Duet 3"
      M569 P0.1 S0
      M569 P0.4 S1
      M569 P0.5 S0
      M569 P0.0 S1
      M584 X0.1 Y0.4 Z0.5 E0.0
      M350 X16 Y16 Z16 E16 I1
      M92 X80.00 Y80.00 Z3000.00 E837.00
      M566 X900.00 Y900.00 Z60.00 E120.00
      M203 X6000.00 Y6000.00 720.00 E1200.00
      M201 X500.00 Y500.00 Z500.00 E250.00
      M906 X800 Y800 Z800 E800 I30
      M84 S30
      M208 X0 Y0 Z0 S1
      M208 X275 Y255 Z285 S0
      M574 X1 S1 P"io1.in"
      M574 Y1 S1 P"io2.in"
      M574 Z1 S1 P"io3.in"
      ; Filament Detection
      M591 P2 C"io4.in" S1 D0
      M558 P0 H5 F600 T6000
      M557 X15:260 Y15:240 S20
      ; Lights
      M950 P3 C"out9" Q500
      M42 P3 S1
      M308 S0 P"temp0" Y"thermistor" T100000 B3950
      M950 H0 C"out0" T0
      M307 H0 R0.321 C318.1 D6.15 S1.00 V23.5 B0
      M140 H0
      M143 H0 S120
      M308 S1 P"temp1" Y"thermistor" T100000 B4138
      M950 H1 C"out1" T1
      M307 H1 R2.333 C200.9 D4.95 S1.00 V23.9 B0
      M143 H1 S280
      M950 F0 C"out7" Q500
      M106 P0 H0 S1 T45
      M950 F1 C"out8" Q500
      M106 P1 H-1 S255
      M950 F2 C"out6" Q500
      M106 P2 H-1 S255
      M563 P0 S"Extruder 1" D0 H1 F0
      G10 P0 X0 Y0 Z0
      G10 P0 R0 S0
      M575 P1 S1 B57600
      M501
      The Diagnostic Report is as follows:
      5/4/2021, 8:37:57 PM: Connected to 192.168.1.15
      5/4/2021, 8:38:11 PM: m122: === Diagnostics ===
      RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9FD-3SJ6N-TB06G
      Used output buffers: 1 of 40 (10 max)
      Static ram: 149788
      Dynamic ram: 62812 of which 64 recycled
      Never used RAM 146168, free system stack 126 words
      Tasks: Linux(blocked,85) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1190) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 11:43:59 ago, cause: power up
      Last software reset at 2021-05-03 19:58, reason: User, none spinning, available RAM 146168, slot 2
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 19.1, current 36.3, max 39.6
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 11.9, current 12.0, max 12.0, under voltage events: 0
      Driver 0: position 0, ok, reads 46899, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: position -40400, ok, reads 46894, writes 19 timeouts 0, SG min/max 0/0
      Driver 2: position 0, ok, reads 46902, writes 11 timeouts 0, SG min/max 0/0
      Driver 3: position 0, ok, reads 46902, writes 11 timeouts 0, SG min/max 0/9
      Driver 4: position 0, ok, reads 46895, writes 19 timeouts 0, SG min/max 0/9
      Driver 5: position 0, ok, reads 46895, writes 19 timeouts 0, SG min/max 0/9
      Date/time: 2021-05-04 20:38:09
      Slowest loop: 97.95ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 7139018ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 10, completed moves 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 168858, send timeouts 380054, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 60269/60269
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.2.2
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 17.93
      Maximum length of RX/TX data transfers: 2800/820
      I can provide more information if it is helpful. I appreciate any help that I can get. Thanks in advance.
      Jon
      o_lampe 1 Reply Last reply Reply Quote 0
      • o_lampe
        o_lampe @jgassett last edited by o_lampe
        @jgassett said in Duet 3 drivers quit working:
        I guess that '720.00' is the value for Z-axis, but there is no letter 'Z'
        Can you try to run M98 P"config.g" on the console to see if any other errors pop up?
        Is this the original driver mapping, or did you change it for testing? Anyway, it doesn't match your description about the driver setup.
        jgassett 1 Reply Last reply Reply Quote 0
        • jgassett
          jgassett @o_lampe last edited by
          @o_lampe Thanks for the reply. Yes - the drive mapping shown in my original post was the final troubleshooting where I was checking the previously unused drivers 4 and 5, neither of which are working. I switched the mapping back to how it was at the time of the crash and tried to move the motors - with no result. I also corrected the Z omission that you caught before trying again. Finally, I ran an M98 P"config.g" as you suggested. The only error that pops up is one related to a heater that is possibly overpowered (its not). Here is the new config.g
          G90
          M83
          M550 P"Duet 3"
          M569 P0.1 S0
          M569 P0.2 S1
          M569 P0.3 S0
          M569 P0.0 S1
          M584 X0.1 Y0.2 Z0.3 E0.0
          M203 X6000.00 Y6000.00 Z720.00 E1200.00
          M84 S30
          M208 X0 Y0 Z0 S1
          ; Lights
          M42 P3 S1
          M950 H0 C"out0" T0
          M140 H0
          M143 H0 S120
          M950 H1 C"out1" T1
          M143 H1 S280
          M106 P0 H0 S1 T45
          M106 P1 H-1 S255
          M106 P2 H-1 S255
          G10 P0 X0 Y0 Z0
          G10 P0 R0 S0
          M575 P1 S1 B57600
          M501
          And here is the new M122 Diagnostic based on those changes:
          5/5/2021, 8:05:33 AM: Connected to 192.168.1.15
          5/5/2021, 8:05:43 AM: m122: === Diagnostics ===
          Used output buffers: 1 of 40 (16 max)
          Static ram: 149788
          Tasks: Linux(ready,107) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1100) IDLE(ready,19)
          Last reset 00:06:54 ago, cause: software
          Last software reset at 2021-05-05 07:58, reason: User, none spinning, available RAM 146208, slot 2
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          MCU temperature: min 36.1, current 36.3, max 36.4
          Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, ok, reads 41617, writes 0 timeouts 0, SG min/max 0/0
          Driver 1: position -40400, ok, reads 41616, writes 0 timeouts 0, SG min/max 0/0
          Driver 2: position 0, ok, reads 41616, writes 0 timeouts 0, SG min/max 0/0
          Driver 3: position 0, ok, reads 41616, writes 0 timeouts 0, SG min/max 9/9
          Driver 4: position 0, ok, reads 41616, writes 0 timeouts 0, SG min/max 9/9
          Driver 5: position 0, ok, reads 41616, writes 0 timeouts 0, SG min/max 9/9
          Date/time: 2021-05-05 08:05:41
          Slowest loop: 0.42ms; fastest: 0.06ms
          === Storage ===
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          === CAN ===
          Messages queued 122, send timeouts 275, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
          RX/TX seq numbers: 14534/14534
          Buffer RX/TX: 0/0-0
          Full transfers per second: 35.12
          Maximum length of RX/TX data transfers: 3868/796
            With the drivers configured and the motors connected are you getting any error messages now when you try and drive them? It sounds like the drivers have failed, but would expect to see some error messages to that effect if that was the case.
            jgassett 2 Replies Last reply Reply Quote 0
            • jgassett
              jgassett @Phaedrux last edited by
              @phaedrux No. Drivers 0, 1, 2, and 3 are configured to drive my axes and extruder. I tried to move them all before printing the last M122 Diagnostic report in my original post. Interestingly (or not) when I execute a "Home All" command, the X homes immediately, the Z indicates homed after about 5 minutes (although the axis never moves, and the DWC indicates the Y axis is trying to home, but it never does. After a bit, it tells me that the Y axis has not homed. I have already tested Drivers 4 and 5 as well (the original M122 in my post) even though I have never used them. It appears that Drivers 2-5 failed in mid-print with a "fault to ground error" but they are now non-functional and I can't reproduce that error.
                When and where did you purchase the Duet?
                • jgassett
                  @phaedrux I also forgot to mention earlier that I am using a SBC setup with a Raspberry Pi 3. I can't see how this could cause the problem, but I wanted to make sure everyone had all the information.
                  • jgassett
                    jgassett @Phaedrux last edited by Phaedrux
                    @phaedrux MatterHackers in February of this year. Receipt attached.
                      Thanks. Please update Matterhackers and let them know we have authorized a warranty replacement. Please include a link to this forum thread as authorization.
                      • jgassett
                        @phaedrux Thank you!
