    Error: Driver 5 does not support x1 microstepping
    • o_lampe
      o_lampe last edited by
      Hi Gents,
      I try to connect an external driver to my Duet2WiFi on P5 (E2 on extension port), but I get the above error
      I got that error even without the tool setting, just by modifying M584, M569, M350
      It's aDuet2WiFi with RRF3.3b2, FWIW.
      Do I have to C"nil" something, before using it as external drive? I couldn't find it in the Wiki.
      Thx for reading
      Olaf
      Here's a short config summary regarding the external stepper
      M584 X0 Y1 Z2 E5                                   ; set drive mapping
      M569 P5 S1  T25:25:25:25                           ; physical drive 5 is external (DUE)
      M350 E1 			; no microsteps, no interlace
      M563 P0 D0 H1 S"nozzle04" F0                     ; define tool 0:     ?? E5 should be D0??
      Here's the full version
      ; Configuration file for Duet WiFi
      ; test-setup for DC-encoder stappers
      M550 P"DuetQDE"                                     ; set printer name
      M552 S1                                   ; enable network and acquire dynamic address via DHCP
      ;M918 P1 E4									; enable 12864
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M350 X16 Y16 Z16 I1                            ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E74.00                   ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E100.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E2800.00            ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z200.00 E1500.00            ; set accelerations (mm/s^2)
      M906 X300 Y300 Z300 I50                       ; set motor currents (mA) and motor idle factor in per cent
      M84 S10                                            ; Set idle timeout
      M208 X-40 Y0 Z0  S1                              ; set axis minima
      M208 X198 Y210 Z200 S0                        ; set axis maxima
      M574 X1 S1 P"xstop"									; optical endstop for low end on X
      M574 Y0 S1                                         ; configure sensorless endstop for low end on Y
      M950 F1 C"fan2" Q5000                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H-1
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S280
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X-25:215 Y15:195 S20                          ; define mesh grid
      M911 S20 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0
      M302 P1	; allow cold extrusions
        @o_lampe said in Error: Driver 5 does not support x1 microstepping:
        Just leave out the M350 E1. You can't set microstepping on an external driver.
        o_lampe 1 Reply Last reply Reply Quote 0
        • o_lampe
          o_lampe @dc42 last edited by o_lampe
          Thanks David,
          I can read the step pulses, but the motor doesn't change direction. I tried to poll the dir-pin in the main loop, but it didn't work.
          Using ISRs for both now.
          Is there a time table diagram, where I can see what's the best strategy to write the interrupt service routines for the receiving Arduino Due?
          I've tried M569 T25:25:25:25 timing, the step signal also works with T5:5:
          I ignore the enable signal ATM. The driver (TB6612 is always enabled)
          My current ISR-setting
          // Falling edge for both
            attachInterrupt(digitalPinToInterrupt(steps_in), step_in, FALLING);
            attachInterrupt(digitalPinToInterrupt(dir_in), directions, FALLING);
          // ISRs:
            void step_in(){ //  read steps from Duet
               in_Steps += 1;
            void directions(){
              dir = digitalReadDirect(dir_in);
          • o_lampe
            o_lampe @o_lampe last edited by o_lampe
            @o_lampe
            OK, I figured out I have to set the dir-interrupt to "CHANGE",.
            Now I can run the DC-encoder motor with M569 T3:3:3:3 timing. 😬
            But it's a bit disapointing how raw the motor moves although there are 8344 QDE-pulses per turn of the output shaft.
            One motor turn delivers 28 QDE pulses and I want to use a 16 tooth gt2 pulley, so the QDE pulses melt down to 8344 / 28 / 32mm= 9.3125 steps/mm. And I can only use full steps, I guess. 😞
              dc42 administrators @o_lampe last edited by
              You can use whatever microstepping your external driver supports. The Duet doesn't need to know what microstepping that is, it just needs to know the microsteps/mm.
              • o_lampe
                Got it, but this driver is a simple dual H-bridge with two inputs for each half. (forward/backwards/break/idle are the options)
                It drives a DC motor, and they don't offer a concept of microstepping. There is only one coil 'active' in a DC motor at a time...
                I thought, the 298:1 gearbox and 28 pulses per motor turn would give plenty of steps/mm, but the motor doesn't stop immediately although the driver has a break mode, where it shorts the motor coils.
                So I have to let the motor run for 28 QDE pulses per incoming step pulse. (that's one motor turn)
                I already have a PWM ramp_down internally to keep overshooting at an acceptable level. But the faster it runs, the more overshooting I see, which makes it hard to eliminate it.
                A simple backlash-correction doesn't help, unless I'd run the motor at constant speed. Which wouldn't be a big issue for feltpen-drawing....
                I have to build a real test rig and see what I can achieve.
                • o_lampe
                  Just to report my new findings,
                  I totally underestimated the crunching power of the Arduino Due. It is very well able to follow every step pulse from Duet, without using internal 'gear ratio'.
                  I can use 256 steps/mm now, which makes it run smoother, but the varying overshoot still persists.
