    2 PWM Fans that each monitor a set of temps across 3 CAN boards
    • gallaghersart
      gallaghersart last edited by
      6HC + 3HC + 3HC merged PWM fans.
      Is this possible. Basically, if any of the 3 boards varies in temperature the fans will adjust.
      1 PWM case fan running off the hottest of the 3 MCU (varying speed). If 6HC is hot then speed up fan. Then if one of the 3HC gets hotter then the fans are speed up for that heat.
      1 PWM Drivers fan trigger on when trinamic drivers on any of the 3 boards get hot or gives warnings.
      Basically, I want 2 PWM Fans that each monitor a set of temps and if any reach a level set, then fans runs.
      Thanks
        dc42 administrators @gallaghersart last edited by
        I think that's possible using 3.2.2 or 3.3 firmware if the fans are connected to the main board.
