    Z motors from deut wifi to duex 5
    Gcode meta commands
    • Sculpt Fabricatorundefined
      Sculpt Fabricator
      We are moving our Z motors from Za and Zb of the duet wifi to the Drive 6, 7, 8, 9 of the duex 5 so they are independently driven instead of wired parallel left and right.
      What code do I need to look for and change so the system knows I moved them?
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Sculpt Fabricator
        @sculpt-fabricator
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
        Edit:
        You have to adapt it for the 4th motor
        (UTC+1)
        Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
          Sculpt Fabricator @DIY-O-Sphere
          @diy-o-sphere
          thanks I had that, what I found and was looing for was the m569 needed to assign each to its own drive
