    temperature reading fault on heater 1
    Firmware installation
    • TRIPZ2757undefined
      TRIPZ2757
      I have a tevo little monster and it wont heat up to load filament all the wires are correct i checked everything
      • SIamundefined
        SIam
        Have you done a PID tuning?
        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • jens55undefined
          jens55
          Might want to post your config file as well.
          TRIPZ2757undefined 1 Reply Last reply Reply Quote 0
            TRIPZ2757 @jens55
            @jens55
            ; Configuration file for Duet Ethernet (firmware version 3.00)
            M550 P"DuetTLM" ; Set machine name
            ;M551 P"password" ; Machine password (used for FTP)
            M552 S1 ; Enable network
            M586 P0 S1 ; Enable HTTP
            M586 P1 S1 ; Enable FTP
            M586 P2 S0 ; Disable Telnet
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            M555 P1 ; Set firmware compatibility to look like RepRapFirmare
            M665 R157 L398 B175 H525 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
            M208 Z0 S1 ; Set minimum Z
            M574 X2 S1 P"xstop" ; X high active high endstop switch
            M574 Y2 S1 P"ystop" ; Y high active high endstop switch
            M574 Z2 S1 P"zstop" ; Z high active high endstop switch
            ; Filament Sensor
            M591 D0 P1 C"e0_stop" S1 ; filament monitor connected to E0_stop
            ; BL-Touch
            ;M558 P9 X0 Y0 Z0 H3 F100 T5000 ; Set Z probe type to unmodulated and the dive height + speeds
            ;M307 H3 A-1 C-1 D-1 ; reserve Heater 3 Pin for M42 or servo use
            M558 P9 C"^zprobe.in" H3 F100 T5000 ; BLTouch connected to Z probe IN pin
            M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
            M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
            ; Offset depending on nozzle size
            ; G31 P25 X0 Y-21 Z1.2 ; Set Z probe trigger value, offset and trigger height for 0.4mm Nozzle
            G31 P25 X0 Y-21 Z1.208 ; Set Z probe trigger value, offset and trigger height for 0.6mm Nozzle
            M557 R150 S15 ; mesh grid
            M350 E32 I0 ; Configure microstepping without interpolation
            M350 X32 Y32 Z32 I1 ; Configure microstepping with interpolation
            M92 X160 Y160 Z160 E1607.45 ; Set steps per mm
            M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
            M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
            M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
            M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M143 S285 ; Set maximum heater temperature to 285C
            M308 S0 P"bed_temp" Y"thermistor" T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
            ;M308 S1 P"e0_temp" Y"thermistor" T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
            M308 S1 P"spi.cs1" Y"rtd-max31865" ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughter board connector
            M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
            M950 H1 C"e0_heat" T1 ; heater 0 uses the bed_heat pin, sensor 0
            M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
            M563 P0 D0 H1 ; Define tool 0
            M950 F0 C"Fan0" Q500 ; Set fan 0 value, PWM signal inversion and frequency.
            M950 F1 C"Fan1" Q500 ; ; Set fan 1 value, PWM signal inversion and frequency.
            M106 P0 S0 H-1 ; Set fan 0 thermostatic control is turned off and switch off fan
            M106 P1 H1 T45 ; Set fan 1 thermostatic control on and start Temp at 45 degree
            M575 P1 S1 B57600 ;panel
            yea idk what im doing wrong everything is connected correctly
            engikeneerundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • engikeneerundefined
              engikeneer @TRIPZ2757
              @tripz2757 might help if you tell us what the exact fault is you're getting...
              Temperature rising too slowly?
              Temperature excursion?
              Etc
              i3 clone with a bunch of mods
                dc42 administrators @TRIPZ2757
                @tripz2757 if you send M308 S1 with no other parameters, it should provide more details of the temperature reading fault.
