    rc servo not moving
    • cosmowave
      cosmowave last edited by
      i have a Duet2 Ethernet running RRF3.3.
      Now i have connected the signal wire of a rc servo to the "exp.heater3" pin.
      The rc servo is powered from an external 5VDC power supply.
      But the servo does not move with M280 P1 Sxx
      xx= i have tried different "S-Values", but no moving was possible...
      my config.g part of the servo:
      M950 S1 C”exp.heater3” Q500	; assign GPIO port 1 to heater3 on expansion connector, servo mode
      M280 P1 S46    			; set (~1deg?) servo position on GPIO port 1 (Servo range 44.2 - 141.2?)
      I have allready checked the power supply of the 5VDC ->ok
      I have wired the Duet GND to the GND of the 5V power supply, so they should be on the same potential...
      Has anyone an idea what i can check additionally, or see an issue with my setup?
      Thanks!
      Mankati FSXT+, DeltaTowerV2, CBot3D
      o_lampe dc42 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @cosmowave last edited by
        @cosmowave
        Sservo pins are just GpOut pins with a different default PWM frequency.
        Maybe you must not overwrite the Servo frequency with 'Q500'?
        cosmowave 1 Reply Last reply Reply Quote 0
          dc42 administrators @cosmowave last edited by
          @cosmowave said in rc servo not moving:
          M950 S1 C”exp.heater3” Q500 ; assign GPIO port 1 to heater3 on expansion connector, servo mode M280 P1 S46 ; set (~1deg?) servo position on GPIO port 1 (Servo range 44.2 - 141.2?)
          Looks like those are the wrong sort of double quote characters in your M950 command. The correct ones look like " not ”.
          • cosmowave
            cosmowave @o_lampe last edited by
            @o_lampe said in rc servo not moving:
            @cosmowave
            I have tried different frequencies, also without a "Q" Value
            @dc42 said in rc servo not moving:
            O yes! You are right! This is a bit embarassing...
            sorry for that, and thanks!
