    Motors loud when running
    • mokash
      mokash last edited by
      Hi everyone, I recently converted my Voxelab Aquila (ender 3 v2 clone) to a duet 3 mini 5+ using the ender 3 guide and now
      my motors a making a very strange sound. They aren't loud like the A4988, they are loud in the sense that they sound wrong. They sound like air leaking from a tank, but with a shallow high frequency beat. Its way louder than my other boards and sounds very wrong like something is not the way it should be.
      The sound is only there during movement, the motors are dead silent during idle. Iv'e tried different modes with similar results e.g. M569 D0-3 ; M350 I0 and I1; and different micro step configurations
      I did have issues with the 5v rail because Creality decided to mess with all wire colors on their version of the bl-touch but once I sorted it the board worked fine. I doubt I caused any damage but worth mentioning.
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 13 2021 11:27:24 GMT-0700 (PDT)
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Groot"                                ; set printer name
      M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0 S0                                 ; physical drive 0.0 goes backwards
      M569 P1 S0                                 ; physical drive 0.1 goes backwards
      M569 P2 S1                                 ; physical drive 0.2 goes forwards
      M569 P3 S0                                 ; physical drive 0.3 goes forwards
      M584 X0 Y1 Z2 E3                     ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1600.00 E417.00           ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E3600.00      ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E2500.00         ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                      ; Set idle timeout
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X220 Y245 Z250 S0                       ; set axis maxima
      M574 X1 S1 P"io5.in"                         ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                         ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"io3.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"^io3.in" H3 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-44 Y-17 Z2.5                      ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                     ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
      M950 F0 C"out3" Q500                         ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"PartEject" S0 H-1                  ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out4" Q500                         ; create fan 1 on pin out4 and set its frequency
      M106 P1 S0 H-1                               ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out5" Q500                         ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"HotEnd" S0 H1 T45                  ; set fan 2 name and value. Thermostatic control is turned on
      M950 F3 C"out6" Q500                         ; create fan 3 on pin out6 and set its frequency
      M106 P3 C"Part Cool" S0 H-1                  ; set fan 3 name and value. Thermostatic control is turned off
      M563 P0 S"HotEnd" D0 H1 F3                   ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      T0                                           ; select first tool
        What firmware version are you running? You should probably be running 3.3 RC2 to take advantage of some bug fixes for the mini5 drivers.
        You can take a look at the stepper tuning page here
        https://duet3d.dozuki.com/Wiki/Tuning_Stepper_Motor_Drivers
        mokash 1 Reply Last reply Reply Quote 0
        • mokash
          mokash @Phaedrux last edited by
          @phaedrux Just updated to 3.3 rc2 no change
