    I want feedback for my enclosure for the Duet 3 mini
    • nikschaundefined
      nikscha
      Hey there, I made an enclosure for the Duet 3 mini + Raspberry Pi + 7i touchscreen
      and as far as I can tell I am the first on Thingiverse to do so.
      You can find it here.
      What additional features would you like to see in the enclosure?
      I am thinking of different mounting options and different fan sizes (current one is 140mm).
      Maybe a different power connector?
      20210515_190523-min.jpg 20210515_190612-min.jpg Screenshot 2021-05-15 184657.png
      Stay in school
        An option for 120mm PC fans would probably be wise since they are more widely available.
        Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 2
        • Luke'sLaboratoryundefined
          Luke'sLaboratory @Phaedrux
          Looks pretty neat!
          A few things -
          1)Under-board Cooling for those drivers.
          2) Wire Tie-down Locations. always useful.
          3) buck converter for the rpi built in? would be neat to plug in only 24v, and have a spot pre-wired for 5v converter and something to hook to the pi.
          Luke
          http://lukeslab.online
          nikschaundefined 1 Reply Last reply Reply Quote 1
          • nikschaundefined
            nikscha @Luke'sLaboratory
            @luke-slaboratory
            Thanks for your suggestions!
            1. I've somewhat implemented underboard cooling. There's holes on the right side and a skirt around the duet, the fan will then push air through the "tunnel".
            2. will implement
            3. good suggestion, didn't think about that at all. My Pi is powerd through the ribbon cable from the duet, which in turn is supplied via the ext_5v_in header from the psu.
            Stay in school
            Michael Hathawayundefined oliofundefined 2 Replies Last reply Reply Quote 0
            • Michael Hathawayundefined
              Michael Hathaway @nikscha
              Hello Nikscha. I have seen this, but I didn't know it was yours. Great job!
              Cut me, I bleed Duet3D. 😳 And I love the people here. 😍😍😍
              www.MatterHackers.com - https://discord.gg/Ked7GREqux
              • oliofundefined
                oliof @nikscha
                @nikscha Two more suggestions: Some space for an SSR for those that run AC beds. Maybe locations for wago connectors for easier cable maintenance.
