    Job.Layer not working anymore with 3.3rc2
    Beta Firmware
    • SIamundefined
      SIam
      Did i have something overlooked? I use this Macro to calibrate PA and it was Working with RFF3.2
      ;Increase pressure advance by 0.005 every 5 layers
      echo "Layer " ^ job.layer
      if job.layer == 1
      	M572 D0 S0.00 ; starting value
      	echo "Layer " ^ job.layer ^ " started"
      	echo "Pressure advance reset to " ^ {move.extruders[0].pressureAdvance + 0.000}
      elif mod(job.layer, 25) == 0 ; no. of layers
      	M572 D0 S{move.extruders[0].pressureAdvance + 0.01} ; increment
      	echo "Pressure advance = " ^ {move.extruders[0].pressureAdvance + 0.000}
      The same script Throws with 3.3rc 2 the following error:
      16.5.2021, 15:56:02	M98 P"0:/macros/pa-calibrate"
      Layer null
      Error: in file macro line 3 column 15: meta command: expected an expression
      Here is The problem that the Value of job.layer is NULL and not 0 so i have tried to fix it with the following change:
      if job.layer != null
      	if job.layer == 1
      The good thing the error is gone but the bad thing job.layer will never updated and stays on NULL I have looked in the object model Browser and here is this message:
      Selected node: job.layer
      Summary
      Number of the current layer or null not available
      Did i something make wrong here? was here a change which i have overlooked?
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      dc42undefined 1 Reply Last reply Reply Quote 1
        dc42 administrators @SIam
        @siam as from 3.3beta2 RRF no longer attempts to work out the layer number from changes in the Z coordinate. It often got it wrong and modern slicer features such as variable layer height confused it. RRF does now recognise layer number comments in the GCode files generated by most slicers. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta-&-RC#reprapfirmware-33beta2.
        SIamundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @dc42
          @dc42 Ok that makes sense thanks !
          • SIamundefined
            SIam @SIam
            @siam if someone have the same issue add the following line (in Prusaslicer) to the G-Code before layer change:
            ; layer [layer_num], Z = [layer_z]
            And use this Script
            	if job.layer == 1
            • nurooundefined
              nuroo
              I was also wondering why I no longer so layer number. Glad I found this thread. Can I ask what model you use with your pressure advance script?
              Do you call your script at end of start gcode?
              • SIamundefined
                SIam @nuroo
                @nurooi use a 100mm cube, 1 bottom layer, 1 perimeters, and no infill. the Script will called on layer change in the slicer
                • JoergS5undefined JoergS5 referenced this topic
