    endstop
    455
    • tazlaundefined
      tazla
      Hi
      got some problem with endstops, due to long cabels and poor shield.
      when i homeing the i/o thinks it has hit the switch as fast the stepper starts
      so is it possible to work around this
      using i/o 7 in and Gnd now on a duet 3 6hc
      //sven
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • tazlaundefined
        tazla
        • Stephen6309undefined
          Stephen6309 @tazla
          @tazla How do have them wired? Using the NC connections helps with noise.
          tazlaundefined 1 Reply Last reply Reply Quote 0
          • tazlaundefined
            tazla @Stephen6309
            @stephen6309 yes got them as NC but the cable length is about 3m
              Stephen6309 @tazla
              @tazla Do you have them set as active high? M119 should only show them as stopped when the endstop is depressed.
              My X & Y are NC and are set as:
              M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io5.in
              M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin io6.in
              • tazlaundefined
                tazla @Stephen6309
                @stephen6309
                M574 X1 S1 P"io7.in" ; configure active-high endstop for low end on X via pin io7.in
                M574 Z1 S1 P"io8.in" ; configure active-high endstop for low end on Z via pin io8.in
                  Stephen6309 @tazla
                  @tazla Use M119 to make sure the endstops are working as intended. It appears the board thinks you're already at the endstop.
                  SIamundefined tazlaundefined 2 Replies Last reply Reply Quote 0
                  • SIamundefined
                    SIam @Stephen6309
                    @stephen6309 have you tried to activate the pull up ?
                    M574 X1 S1 P"^io7.in" ; configure active-high endstop for low end on X via pin io7.in
                    Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                    Duet WiFi 1.02 or later + DueX5
                    RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                    Duet WiFi Server: 1.26
                    Duet Web Control 3.4.0beta4 (2021-09-27)
                    • tazlaundefined
                      tazla @Stephen6309
                      @stephen6309
                      when the y axis is homeing it moves just 5-6mm stops, and does it in slow speed after and shows up as homed
                      but if i take a cable an short the connection block . it moves all the way.
                      thats why i wonder if the ii/o feels the powerrush for the stepper and thinks it is home somehow
                      • tazlaundefined
                        tazla @SIam
                        @siam
                        not yet im a complete newbi on this but will try tomorrow
                        what does that do exactly?
                        SIamundefined 1 Reply Last reply Reply Quote 0
                        • SIamundefined
                          SIam @tazla
                          @tazla The pull up sets the Input port to a defined voltage
                          • tazlaundefined
                            tazla @SIam
                            @siam
                            do i have to change pins from (io7 in and Gnd ) to use the pull up
                            • SIamundefined
                              SIam @tazla
                              @tazla no
                              • tazlaundefined
                                tazla @SIam
                                @siam had to go back to try it but it wasent any change
                                • tazlaundefined
                                  tazla @tazla
                                  @tazla if i would setup 3 relays for endstop switches and just use24v for the them
                                  would that be bad somehow?
                                  • tazlaundefined
                                    tazla @tazla
                                    @tazla said in endstop:
                                    i made a 24v circuit to a relay and that worked
