    LASER Filament sensor issues still haunting me
    Filament Monitor
    • mendeleviumundefined
      mendelevium
      I have my printer with dual extruders...
      I am performing trial prints to check if all is well but I am still encountering issues...
      I have the following in Config;-
      M591 D0 P6 C"e0stop" R1:600 E3 S1
      M591 D1 P6 C"e1stop" R1:600 E3 S1
      I am trying to print with Extruder 1
      as soon as I try a print, I get an error that I do not have No Filament in extruder 0
      I cancel and resume...
      I get an error that I do not have filament in Extruder 1
      My Question 1 ;- Why do I get an error connected with extruder 1 when I am working with extruder 0 ?
      I put filament in the extruder 1 just enough to activate the filament present microswitch
      the machine still pauses and tells me there is no filament in Extruder 0 again.
      the error related to extruder 1 is not present any more. Looks like whether I am using extruder 0 or extruder 1, filament must be present in both extruders. Is this correct?
      I try to print and still the machine does continue to bring the error for extruder 1...
      Then I push the command;- M591 D0 P5 C"e0stop" R1:600 E3 S1 ( No filament present micro-switch) machine works.
      This is sending me crazy... Can anybody suggest some tests i can do?
      Note that when I switch on the machine, the LED flash correctly as described ....
        What firmware version?
        If you disable the filament sensor that is not currently in use, does it still complain?
        mendeleviumundefined 1 Reply Last reply Reply Quote 0
          mendelevium @Phaedrux
          @phaedrux
          I have firmware version 3.
          I will try what you suggest, however will take a day or two as I have taken the controller off to complete the case...
            dc42 administrators @mendelevium
            @mendelevium said in LASER Filament sensor issues still haunting me:
            Exactly which version? Send M115 to find out.
