Unsolved Providing 5V to the Duet3 via the 3-pin PS_ON...
@dc42 I have a dedicated 5v PSU that can supply 6amps, and have been running the Duet3 with a Pi4. I have the 5v PSU connected to the +5v pin on the connector to provide power to the Duet3 (and I believe) to the Pi4 via the cable. Is this an acceptable means of supplying power, or should I NOT supply 5v to that pin, and instead let the Duet3 internally provide 5v, and then connect the Pi4 directly to the PSU instead?
Oh, as an aside, I recall in the roadmap, that you were going to provide a way to invert the M80 command for Meanwell style ATX power control - is that still a thing?
