Accelerometer D3 6hc Stabdalone ?
How can I use the accelerometer on the duet3 6hc in standalone,
if I have no network and no display (paneldue)?
Is it possible to write a Marco that homing after a timer of 5 minutes and then the recording?
If you then switch from SBC again, you edit this function in Config.g.
Would that be possible? -
@heartleander81 you can send the commands over USB; but read the wiki page on avoiding USB ground loops first. Alternatively, put the commands in a macro and use a spare input and M581 trigger to execute it on demand.
@dc42 Is it normal for the accelerometer to whistle?
@heartleander81 said in Accelerometer D3 6hc Stabdalone ?:
No! Are you sure it is the accelerometer whistling?
@dc42 yes. I think go on the wrong pins. Must I go on spi0 ore spi1 ?
@heartleander81 you connect the accelerometer to the SPI pins on the temperature daughter board connector.
@dc42 ok then is it ok. This pins I have used.
@dc42 ok no is the Hotend Fan not the accelerometer.. sorry
@dc42 I am embarrassed. Thought the Pi read the firmware data from the 2nd directory. But that was not the case, so I had the noise from the fan. I saved the Pi settings to create a standalone SD card. Now I just have to find out whether you move X and Y alone or together.
I suggest you collect accelerometer data for movements of just one axis at a time.
