    Help to set up Duet IR Probe
    229
    • A Former User
      Dear all
      I have installed the original IR Probe Duet sensor in my Ender 3 with the Duet Mini 5+ .
      Installation and configuration it is all ok.
      1. The system detect the sensor with the right lights
      2. I have set in the firmware the height using the G92 Z0
      3. Send the command G30-S1 to test the Probe sensor and stops correctly before touching the bed (probably 1 or 2 mmm before touching the bed)
      4. I have repeated the steps multiple times to confirm the height of the nozzle in reference to the IR probe sensor
      5. I have declared the Z trigger height in my config.g file and checked is not duplicated in my config-override.g file
      6. Finally trigger height using M999 command
      As you can see after this I have ran the bed leveling with success, but when I trying to print, the Nozzle start to scratch my bed from the very beginning.
      I am sure that I am missing something but I am new in this kind of setting up a Probe sensor, always I was doing manually.
      I have follow with attention the guides in your forum and other other sites but still I dont find the issue in my config.g file.
      I know you guys can find the issue easy, here is my config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon May 17 2021 14:10:06 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Ender 3 Pro"                                ; set printer name
      M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                       ; physical drive 0.3 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E93.00                   ; set steps per mm
      M566 X1200.00 Y1200.00 Z60.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z600.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z200.00 E5000.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X235 Y235 Z260 S0                             ; set axis maxima
      M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S1 P"io2.in"                               ; configure active-high endstop for low end on Z via pin io2.in
      M558 P8 C"io3.in" H5 F120 T6000                    ; disable Z probe but set dive height, probe speed and travel speed
      G31 X-0 Y0 Z-1.3
      M557 X40:215 Y40:195 S30                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T98801 B4185        ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S80                                        ; set temperature limit for heater 0 to 80C
      M308 S1 P"temp1" Y"thermistor" T98801 B4185        ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S240                                       ; set temperature limit for heater 1 to 240C
      M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"PartCool" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"HotEnd" S1 H1:0 T45                      ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"CaseFan" S1 H1:0 T45                     ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"HotEnd" D0 H1 F0                         ; define tool 0
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      M501                                               ; load saved parameters from non-volatile memory
      T0                                                 ; select first tool
      I have here some photos
      Thank you
      • droftarts
        droftarts administrators @Guest last edited by
        @javcab said in Help to set up Duet IR Probe:
        G31 X-0 Y0 Z-1.3
        The Z offset should be positive; think of it as the nozzle height when the probe is triggered. See point 7, https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
        For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
        You also haven't set your X and Y offsets. X will be something like -30, Y will be close to 0.
        Also be aware that, because your bed is not black all over, the probe may respond differently over the white areas.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @droftarts last edited by
          @droftarts @droftarts
          Hi, very useful your help to setup much better my offset for X and Y.
          Still I have the problem in the beginning. When the printer is in Home position (left-down) and I start a print, the nozzle hit the same left corner. There is a way to add in the code to avoid the contact with the bed?
          I am trying to follow some guides but I am still not understanding how I can add the parameter in the code to avoid the bed. I mean I just need to put the nozzle a little bit higher when start to move from the home position.
          Right now I am thinking in to change the position of Home to the center of the bed, probably this is easier. I dont know.
          Thanks
          Javier
          • droftarts
            @javcab is it because Z homes in the corner, so the IR probe is off the bed? Change the homing position in homeall.g and homez.g. It’s the G1 X… Y… line just before G30. Often it is X15 Y15. Change it to the coordinates of the centre of the bed. Post your homeall.g if you are not sure.
            For changing to X0 Y0 in the centre of the bed (I have all my printers set up this way) see https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
            A Former User 2 Replies Last reply Reply Quote 0
            • A Former User
              @droftarts Yes, is out of the bed the home in my Ender 3.
              Very in the left-down corner
              I will try and follow your indications and let you know how is going
              Thank you
              • A Former User
                @droftarts Well, I dont have G30 in my homeall.g and homez.g
                Can you help me explaining what that I need to put there?
                here my homeall.g
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 21:19:18 GMT+0200 (Mitteleuropäische Sommerzeit)
                G1 H2 Z5 F6000          ; lift Z relative to current position
                G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000       ; go back a few mm
                G1 H1 X-240 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
                G1 H1 Z-265 F360        ; move Z down stopping at the endstop
                G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                ;G91                    ; relative positioning
                ;G1 Z5 F100             ; lift Z relative to current position
                ;G90                    ; absolute positioning
                And here my home z.g
                ; homez.g
                ; called to home the Z axis
                G1 H1 Z-265 F1800 ; move Z down until the endstop is triggered
                Thank you very much
                  Phaedrux Moderator @Guest last edited by
                  You need to replace those lines with
                  G1 X150 Y150 F6000 ; position probe at center of bed
                  G30 ; probe for Z0
                  Right now you are setting Z0 with an endstop rather than the probe. Hence this incongruent height.
                  After changing to G30 to use the probe, you should redo the mesh compensation (G29)
                    Also check your trigger height again. a negative trigger height means the nozzle tip is BELOW the bed surface.
