Restart after print start
Hi guys,
my printer always restarts after starting the G-Code. Duet is responding "Connection interrupted http request time out" (probably because of the restart and the failed connection). I restarted my router and used the wifi reset macro, but nothing worked. The same result by printing from SD-Card or PC. Do you guys have any ideas?
Simon -
@simon-0 if you ever get an unexpected reset of the Duet, run M122 as soon as it reconnects and post the result here.
Last reset 00:00:37 ago, cause: power up
The reset was caused by the PSU cutting out.
@dc42 how can i fix it?
Problem solved. The heater was broken. Thanks for helping!
