    Solved Error: This kinematics does not support auto-calibration
    • Stephen6309
      Stephen6309 last edited by
      Cartesian printer. Duet Mini 5+ in standalone, with 1LC both have 3.3RC2. Z motors on drivers 2 & 3. Used the wiki to set it up.
      Autolevel Macro:
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
       G28 ; home
      G30 P0 X20 Y140 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X270 Y140 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      It runs fine then I get the error.
      M671 in in the Custom settings section.
      Config.g:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 16 2021 12:00:09 GMT-0400 (Eastern Daylight Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"M-Max"                                             ; set printer name
      M669 K0                                                   ; Cartesion mode
      M552 S1                                                   ; enable network
      M586 P0 S1                                                ; enable HTTP
      M586 P1 S0                                                ; disable FTP
      M586 P2 S0                                                ; disable Telnet
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                              ; physical drive 0.2 goes backwards
      M569 P0.3 S0
      G4 S1
      M569 P121.0 S0                                            ; physical drive 121.0 goes backwards
      M584 X0.0 Y0.1 Z0.2:0.3 E121.0                                ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
      M92 X88.10 Y88.10 Z2133.30 E836.00                        ; set steps per mm
      M566 X600.00 Y600.00 Z60.00 E600.00                       ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z180.00 E6000.00                 ; set maximum speeds (mm/min)
      M201 X4000.00 Y4000.00 Z150.00 E750.00                    ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E1200 I30                           ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X300 Y280 Z200 S0                                    ; set axis maxima
      M574 X1 S1 P"io5.in"                                      ; configure active-high endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                                      ; configure active-high endstop for low end on Y via pin io6.in
      M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T6000                      ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X20 Y0 Z0                                        ; set Z probe trigger value, offset and trigger height
      M557 X5:300 Y5:280 S40                                    ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092              ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                              ; set temperature limit for heater 1 to 300C
      M950 F0 C"121.out1" Q500                                  ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 C"Parts" S0 H-1                                   ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                                  ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 C"Hotend" S1 H1 T45                               ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M950 F0 C"out1" Q500                                      ; create fan 0 (parts) on pin out1 and set its frequency
      M376 H5                                                   ; taper bed compensation
      ;M572 D0 S0.05                                            ; pressure advance
      M207 S1.5 F6000	R0 Z0.03                                  ; firmware retraction
      M593 F23                                                  ; set dynamic acceleration
      M671 X0:280 Y:0:0 S0.75		                                ; define the two Z leadscrew test-positions and max correction of 0.75
      G10 P0 S0 R0                                              ; set T0 heater off
      M150 R0 U0 B0 P5 S8 F0                                    ; shut off neopixel
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      M501                                                      ; load saved parameters from non-volatile memory
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
      T0                                                        ; select first tool
        dc42 administrators @Stephen6309 last edited by
        @stephen6309 send M671 without parameters to check that it has accepted your M671 command.
        Stephen6309 1 Reply Last reply Reply Quote 0
        • Stephen6309
          Stephen6309 @dc42 last edited by
          @dc4Z M671 Returns: leadscrew coordinates are not configured
          But I do have a M671 defined.
          jay_s_uk 1 Reply Last reply Reply Quote 0
          • jay_s_uk
            jay_s_uk @Stephen6309 last edited by
            @stephen6309 said in Error: This kinematics does not support auto-calibration:
            You have an extra :
            Should be
            M671 X0:280 Y0:0 S0.75
            Stephen6309 1 Reply Last reply Reply Quote 1
            • Stephen6309
              Stephen6309 @jay_s_uk last edited by
              @jay_s_uk Dang computers. 😲 Removing the : fixed it.
