Default acceleration values
Hi. I have a doubt: by using M201 I set the max accel used for every axis. Then using M204 I can set printing and travel accel in an independent way. Question is: what happen if I dont setup the M204 values? Printing accel by will be the one set in the M201 command by default?
Thanks in advance -
@tinchus said in Default acceleration values:
Thanks in advanceFrom the wiki (quote)
"Use M201 to set per-axis accelerations and extruder accelerations. RepRapFirmware applies the M204 accelerations to the move as a whole, and also applies the limits set by M201 to each axis and extruder."
Yes, because the default for M204 is set very high, 10000 mm/sec^2.
