    LIS3DH +SAMMYC21(chip45)+Duet 3 Mini
    467
    • Sotidiiundefined
      Sotidii
      Good day !
      Where can I find instructions for connecting and setting up?
        dc42 administrators @Sotidii
        https://duet3d.dozuki.com/Wiki/Accelerometers#main
        Sotidiiundefined 1 Reply Last reply Reply Quote 0
        • Sotidiiundefined
          Sotidii @dc42
          @dc42 I watched this, I could not understand how to connect and configure SYMMYC21
            @sotidii if you have purchased the SAMMC21 with the Duet3D bootloader pore-installed, then you can just connect it to your CAN bus and install firmware file Duet3Firmware-SAMMYC21.bin from the RRF 3.3RC2 release. You will need to provide power to the SAMMYC21 through its USB connector.
            PS - also see https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3 if you haven't already.
            • Sotidiiundefined
              Sotidii @dc42
              @dc42 Thank you ! working!
              • Sotidiiundefined
                Sotidii
                Is it possible to connect BLtouch to Sammyc21
                o_lampeundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • o_lampeundefined
                  o_lampe @Sotidii
                  @sotidii said in LIS3DH +SAMMYC21(chip45)+Duet 3 Mini:
                  It's recommended to put the Z-probe on the same board as the Z-motor(s). A CAN bus between motors and probe would cause delay.
                    Yes, it's possible. See the pin table at https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3#Section_Features_of_the_standard_firmware_binary. Pick a pin capable of PWM output for the servo control wire, and a pin capable of digital input for the input pin.
