    Duet 3 mini, RRF 3.2.2 - Error logfile? +DWC stopped.
    Using Duet Controllers
    • CNCModellerundefined
      CNCModeller
      Hi All,
      I woke this morning to find my printer paused with an error on the 12864 display but the error wasn't fully readable as it went off the right of the display. Something like "Too Much..." Or "Too high..." It was the middle of the night and I was half asleep when I checked the printer lol.
      It could be filament as I haven't calibrated it properly yet.
      By the looks of the print it was probably 3 or 4 hours in to a 20h test print.
      Unfortunately DWC also locked up, I was running one instance on my pc, and another on my phone.
      Is there a logfile on the SD I can look at to see what the error was that caused the pause?
      Is it likely the pause caused DWC to stop? Or am I looking at another fault?
      Also is there any way to trigger an alert on my phone for print errors?
      Any thoughts would be much appreciated.
      Many thanks
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @CNCModeller
        @cncmodeller
        Check this:
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M929_Start_stop_event_logging_to_SD_card
        Edit:
        Triggering would be possible e.g. with a node red flow.
        https://forum.duet3d.com/topic/18520/node-red-mobile-sized-status-dashboard-for-duet?_=1621839970014
        https://github.com/MintyTrebor/Duet-Node-Red-Dashboard
        (UTC+1)
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
          CNCModeller @DIY-O-Sphere
          @diy-o-sphere said in Duet 3 mini, RRF 3.2.2 - Error logfile? +DWC stopped.:
          @cncmodeller
          Check this:
          Edit:
          Thanks @DIY-O-Sphere , I'll check out the logging function.
          My home automation works with MQTT and OpenHab I think I already have a link to an MQTT interface somewhere, will have to check it out in more detail once the printer is fully operational again after its upgrade.
          Thanks again,
          Barry M
          Wanhao D4S: Duet2
          K40 Laser, Duet2
          Wanhao D5S
            You could gather an M122 if you haven't power cycled more than once to see if there's something useful in there for use to see.
            For monitoring there are a few options lists here: https://duet3d.dozuki.com/c/Community_Projects
