    IDEX printer axis motor sizing question
    • JKlaus
      JKlaus last edited by JKlaus
      I am building a 600x600x200 idex printer with a moving gantry.
      Because the gantry is going to be moving on the Y I am trying to keep the weight down.
      I am wondering it a pancake stepper would be able to get the job done.
      The moving mass of each extruder if going to be close to 500g all inclusive.
      That is a 270g Bondtech LGX FF and a 100g mgn12h carriage and a bit extra for brackets.
      Specifically I am looking at the LDO 42STH20-1004AS "Super Slim" motor.
      I will be running a 16T motor pulley to help the give the motor a little more help.
      With all the other mass that I am trying to throw around I would love to use a pair of these small motors to minimize the moving mass.
      Thanks.
      • Luke'sLaboratory
        Luke'sLaboratory last edited by
        For what its worth, I chuck a 5kg bed around with a single nema 17 at ~3k acceleration on a standard bedslinger with a 400x400mm bed. If its really a concern, use two seperate y motors to move the entire gantry.
        Otherwise you should be fine.
        Luke
        http://lukeslab.online
        JKlaus 1 Reply Last reply Reply Quote 0
        • JKlaus
          JKlaus @Luke'sLaboratory last edited by
          @luke-slaboratory
          For moving the gantry itself I do actually have it being moved by 2 separate large steppers.
          They are stationary so I don't care about their weight.
          But the X axis motors that move the extruders are moving on the gantry so I want to keep their weight to a minimum.
          Luke'sLaboratory o_lampe 2 Replies Last reply Reply Quote 0
          • Luke'sLaboratory
            Luke'sLaboratory @JKlaus last edited by
            @jklaus
            Right - those X-axis motors are carried by your Y-axis motors, correct? if the Y-axis motors are strong enough and your gantry rigid, going with "big enough" X-axis motors should be more of a concern than saving <5% of the total mass of your Y-gantry, IMHO.
            Luke
            • o_lampe
              o_lampe @JKlaus last edited by
              @jklaus said in IDEX printer axis motor sizing question:
              I'm using a similar (slightly stronger) motor on The Hitchhiker. It drives a 16 teeth pulley through a 5:1 spur gear (BMG extruder parts)
              I can reach upto 200mm/s speed with reasonable acceleration. Without a reduction gear i wouldn't expect too much.
              The Hitchhiker
              • JKlaus
                @luke-slaboratory
                True, running the numbers in Inventor my whole moving gantry assemble will run right at 11 pounds with everything but the X motors.
                The small ones add on about another .6 pounds for both.
                While a larger motor with double the torque would be about 1.3 pounds for both.
                My Y is driven by 2 motors each with their own driver so throwing around that weight shouldn't be too hard.
                And since they aren't moving I always have the option to go even larger on Y if necessary.
                My only real concern with the weight is when the Z is getting high I am concerned about possible ringing.
                The X axis looks to be 4.4 pounds without motors.
                Growing to 5.0 or 5.7 pounds for small or large X motors.
                Maybe I am just worrying too much about this and I should go for the large motors.
                The connection between the gantry and Y bearing blocks is about as sturdy as I could make it without just being a chunk of aluminum.
                @o_lampe
                That is a pretty interesting setup with a geared moving axis motor.
                I haven't seen a setup using a bondtech gear setup to drive an axis before.
                That plus something light like an orbiter on top would make a pretty sweet and light direct drive setup.
                o_lampe 1 Reply Last reply Reply Quote 0
                • o_lampe
                  I'm pretty happy with it, although I'd refine the design here and there. ATM I have some backlash in the gears, which causes quality issues.
                  It works best as 'big nozzle infill extruder'.
                  RRF doesn't have backlash correction for moving axes and I'm also waiting for a way to add an independent mini-Z-axis for mesh leveling.
                  (hence the dovetail slider)
