    Home to Z max but also probe z min?
    Using Duet Controllers
    103
    • CNCModeller
      CNCModeller last edited by
      I'm currently homing to Z min with a bltouch, but want to setup power loss recovery, which will require homing to Z max, as the print will be in the way on restart.
      My z min location / probed bed height changes slightly depending on which bed surface I'm using so I can't just use preset values.
      Any thoughts on how to best achieve this?
      Many thanks
      Barry M
      Custom Large format Polar Printer running Duet 3 Mini +.
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Also Wanhao D5s and D4s, Duet 2/3 control TBD.
      https://www.youtube.com/CNCModellerUK
      https://www.CNCModeller.co.uk
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @CNCModeller last edited by
        @cncmodeller probe the bed and then measure Z Max using G1 H3.
        Then save it as part of the config-override using M500
        Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
        CNCModeller 1 Reply Last reply Reply Quote 0
        • CNCModeller
          CNCModeller @jay_s_uk last edited by
          @jay_s_uk said in Home to Z max but also probe z min?:
          Thanks @jay_s_uk I'll give that a try. 🙂
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt @CNCModeller last edited by
            @cncmodeller said in Home to Z max but also probe z min?:
            Do you have an endstop sensor positioned at Z max?
            Thanks.
            Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
            jay_s_uk CNCModeller 2 Replies Last reply Reply Quote 0
            • jay_s_uk
              jay_s_uk @fcwilt last edited by
              @fcwilt i do on my ender 3 although I don't use it much.
              • CNCModeller
                CNCModeller @fcwilt last edited by CNCModeller
                @fcwilt said in Home to Z max but also probe z min?:
                Thanks.
                @fcwilt
                I have a movable z max endstop on a magnetic base that I can position just above my max print height. The z axis is 1200mm tall so a full height z zmax move takes a while. Z moves have to be slow to prevent the z axis lead screw from whipping.
                Albeit now I have conditional gcode available I could schedule z move homing speed with height above the bed, will look into that 🙂
                • fcwilt
                  I take it that the lead screw is not constrained at the free end?
                  I have found that constraining the free end works better which is contrary to common advice.
                  • CNCModeller
                    Unfortunately if you constrain the free end your going to get z wobble, especially on a long lead screw like this as they are never perfectly straight.
                    I had big issues with this on my Wanhao D5s.
                    • fcwilt
                      As I said what I have found for my printers is that constraint works better but I have kinetic bed mounts which allow for some lateral motion from the lead screws so perhaps that is why it works in my case.
                      That said my most recent printer was recently converted to 3 Z steppers using belt drive and based on my experience with that printer I believe I will be using that approach for all new printers if applicable.
