    Pin names for Stop 10 and 11 Duet WIFI
    • Ericundefined
      Eric
      Hello Duet team,
      I cannot find the stop 10 and 11 pins in the pin names dictionary for the duet WIFI
      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
      They are in the stepper channel 10 and 11
      https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
      What are the names for these? "stop 10" and "stop 11"? Thanks in advance!
      With regards,
      Eric Wieland
      o_lampeundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Eric
        @eric
        Their names should be 'ENC_A' and 'ENC_B' located on the Conn_LCD header.
          droftarts administrators @Eric
          @eric If I'm reading the pin table correctly, I think the pin names are:
          connlcd.encb or connlcd.3 (for Stop 10)
          See https://github.com/Duet3D/RepRapFirmware/blob/c565f35304b0d872d8671584dd6341ce13a82bbf/src/DuetNG/Pins_DuetNG.h#L346
          connlcd.enca or connlcd.4 (for Stop 11)
          See https://github.com/Duet3D/RepRapFirmware/blob/c565f35304b0d872d8671584dd6341ce13a82bbf/src/DuetNG/Pins_DuetNG.h#L279
          • Ericundefined
            Eric
            Hello Ian,
            These work thanks! It's maybe a good idea to update the documentation.
            With regard,
            Eric
