    RFI EMI Noise Suppressor for cables
    • gallaghersart
      gallaghersart last edited by
      My goal is to have many high speed FDM printers in same room, and as close to each other as I can.
      I’m using 18AWG Shielded Stranded wires.
      Would it benefit from adding magnetic RFI EMI Noise Suppressor to each wire? And if so should I place one at motor or drive end of cable? Or both?
      Thanks!
      `mike
        Are you worried about EMI between machines in the same room? I'd be more worried about wires within the same machine (endstops/steppers/sensors).
        Braiding and twisting the wires is usually enough and using good grounding techniques for steppers and frame.
        Do you mean ferrite cores/chokes likes these?
        gallaghersart 1 Reply Last reply Reply Quote 0
        • gallaghersart
          gallaghersart @Phaedrux last edited by
          @phaedrux Thanks, those are like what I'm talking about, just not name brand.
            @gallaghersart you may find this interesting https://forum.duet3d.com/topic/22385/emc-wiring-for-duet-2-ethernet.
