    Repeating G32 until level
    Gcode meta commands
    • Nurgelrot
      Nurgelrot last edited by
      So I have and Mini5+/Ender 5 Plus and the Z axis gets tilted pretty easy (especially when I m working on the printer and moving it etc). So I have a bed.g file defined and the lead screws set in config.g and G32 is working. But I'd like the G32 command to repeat until the bed is level right now I have to re-run it manually until i get down to a reasonable level. How do I go about that?
      here is what I have now:
      bed.g
      ; Bed file for Ender 5 Plus with probe offset of -45 -7 (creality default)
      M561                                                       ; clear any bed transform
      G29 S2                                                     ; Clear bed height map
      ; Probe point
      M401                                                       ; Deploy probe - deployprobe.g
      G30 P0 X47 Y187 Z-9999                      ; Left
      G30 P1 X315 Y187 Z-9999 S2              ;Right
      M402                                                   ; Retract Probe - retractprobe.g
      config.g
      G31 P500 X-45 Y-7 Z1.69                             ; set Z probe trigger value, offset and trigger height
      M671 X-23:386 Y180:180 S3	                ; Define lead scew locations
      M557 X5:315 Y5:345 S30                             ; define mesh grid
      Like I said all this works fine I just want it keep running until both Z are within .00x
      Thank you.
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @Nurgelrot last edited by
        @nurgelrot
        Here is an example of a file I created for another member.
        The values are for his printer.
        There are some macro calls which have comments which say what they do.
        Feel free to ask questions.
        ; bed.g
        ; called to perform bed leveling procedure
        ; G32 will invoke this file
        M98 P"homeALL_verify.g" ; verify printer has been homed
        ; M671: Define positions pf manual bed leveling screws or Z leadscrews
        ; Xnn:nn:nn... list of between 2 and 4 X coordinates of the leadscrews that drive the Z axis or the bed levelling screws
        ; Ynn:nn:nn... list of between 2 and 4 Y coordinates of the leadscrews that drive the Z axis or the bed levelling screws
        ; Snn          maximum correction allowed for each leadscrew in mm (optional, default 1.0)
        ; Pnnn         pitch of the bed levelling screws (not used when bed levelling using independently-driven leadscrews). Defaults to 0.5mm which is correct for M3 bed levelling screws
        ; Fnn          fudge factor, default 1.0
        ; update the M671 command below with the correct values
        M671 X327:327 Y520:-95 S6 ; positions of Z lead screws
        ; --- perform bed leveling ---
        while true
          ; run leveling pass
          ; NOTE: when G30 is invoked with a P parameter the Z probe X and Y offsets are taken into account
          ; update the G30 comands below with the correct values
          ; method 1 - probe near lead screws
          G30 P0 X327 Y50  Z-99999    ; probe near lead screw #1
          G30 P1 X327 Y425 Z-99999 S2 ; probe near lead screw #2
          ; method 2 - probe near corners of bed MAY NOT BE POSSIBLE GIVEN THIS PRINTER STYLE
          ;G30 P0 X???  Y??? Z-99999    ; Left  Front
          ;G30 P1 X???  Y??? Z-99999    ; Left  Rear
          ;G30 P2 X???  Y??? Z-99999    ; Right Rear
          ;G30 P2 X???  Y??? Z-99999 S3 ; Right Front
          ; check results - exit loop if results are good
          if move.calibration.initial.deviation < 0.02
            break
          ; check pass limit - abort if pass limit reached
          if iterations = 5
            M291 P"Bed Leveling Aborted" R"Pass Limit Reached"
            abort "Bed Leveling Aborted - Pass Limit Reached"
        ; --- finish up ---
        ; --- set Z=0 datum which can be affected by leveling ---
        M98 P"probe_set_z.g"          ; set Z=0 datum
        Nurgelrot o_lampe 4 Replies Last reply Reply Quote 2
        • Nurgelrot
          Nurgelrot @fcwilt last edited by Nurgelrot
          @fcwilt I think I get the gist of that I'll write mine up and see how it works out. Thank you.
          • o_lampe
            o_lampe @fcwilt last edited by
            This post is deleted!
            • Nurgelrot
              @fcwilt Yep Thanks for the help Put my settings inside the loop like you have. Works perfectly.
              • o_lampe
                @fcwilt
                If there's a Meta-code repository, it would be nice to post it there. too.
                Maybe with variables for iteration-depth and deviation-target. Placed at the beginning of the file, they are easier to find for all of us.
