    Solved Duet 3 mini problem again !!!!!
    113
    • peter247
      peter247 last edited by peter247
      o.k , With all the config.g disappearing on the mini I thought I better check things out , so I just changed the printer name and neatened up the comment , saved and rebooted and got this :
      Connection interrupted, attempting to reconnect...
      Unexpected token < in JSON at position 0
      Replaced the config.g from the known working version and still get the same error.
      Now every time I try to change config.g I get the error .
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        Are you in SBC mode?
        Do you have a password set?
        peter247 1 Reply Last reply Reply Quote 0
        • peter247
          peter247 @Phaedrux last edited by peter247
          @phaedrux Yes a password is set .
          I've shut down the web page and started a new and the password works .
          Yes , standalone mode .
          I've tried a Emergency stop and no error message , tried editing other files no error , but I get the error message now if I try to edit config.g
          is their a way to check the config.g for errors ?
            What firmware and DWC version? What browser?
            There had been some similar error messages before but were believed to be resolved.
            https://forum.duet3d.com/topic/19967/3-2-beta-3-2-unexpected-token-in-json-at-position-0/7?_=1610891955515
            peter247 2 Replies Last reply Reply Quote 0
            • peter247
              @phaedrux
              RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
              Board ID: MZSV6-S096U-D65J0-40KMD-3413Z-R7859
              • peter247
                @phaedrux o.k stopped all plug ins , tried chrome and edge with the same result .
                checked line by line for errors , retyped my password.
                which other files could it be ?
                  If you remove the password does it work?
                  What is the DWC version? Also 3.2.2?
                  • peter247
                    @phaedrux Password removed do I get a error ?, wow no error !!!!
                    Board: Duet 3 Mini 5+ (Mini5plus)
                    Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.2.2 (2021-02-11)
                    Duet WiFi Server Version: 1.25
                    That is what it came with, not done any upgrade waiting for the next stable.
                    tried putting the password back on and errored again .
                      Phaedrux Moderator @peter247 last edited by Phaedrux
                      @peter247 said in Duet 3 mini problem again !!!!!:
                      Sorry this doesn't indicate the DWC version. You'd have to check within DWC under the general/machine specific tab.
                      This problem was believed to have been solved in 3.2.2 which is why I wonder if you have an older version of DWC.
                      If in doubt, just upload this full zip file to the system tab in DWC to ensure it's all updated.
                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                      • peter247
                        @phaedrux
                        That was from the machine specific tab , But the general / general tab says :-
                        Duet Web Control 3.2.0
                        o.k updated via your link now says: Duet Web Control 3.2.2 , password back on and no errors .
                        Thank you !!
