    Homing X and Y works, Z loses its mind.
    • Mentaluproarundefined
      Mentaluproar
      I am slowly learning how to use a duet and really liking it over my old ramps and octoprint setup. I am stuck with homing my machine on Z. It is a Cartesian bot. Nothing too unusual about it. I managed to figure out why it crashed into the bed, but now I cant get it to stop trying to move X and Y outside their limits while homing Z.
      I took a video of it. I know it’s slow, but I haven’t gotten to tuning speed yet. Right now, I’m just trying to make everything work.
      https://m.youtube.com/watch?v=9_s5cxFU4OQ
      Where am I messing up?
      • deckingmanundefined
        deckingman
        We could do with a bit more information but at a wild guess, based on the video, I'd say that you may have deploy and retract probe files in the .sys directory and you have the latest firmware which will run these files. But you have an IR probe which doesn't need to be deployed and retracted. So, check the .sys folder for deploy probe ad retract probe files and if they exist, delete them.
        If that doesn't fix it, let us know what firmware version you are running, and also please post your homez file.
        HTH
          Mentaluproar
          You were right! Remove the deploy and retract files fixed Z probing. But now I'm having trouble homing Y. I thought I had it right, but then when I tried to create a mesh, the machine kept trying to pull the bed past the minimum every time it was supposed to advance a row. I'm also not sure I have the Y settings right and I think I made them worse. I'm running 1.19.
          config.g
          ; Configuration file for Duet WiFi (firmware version 1.17)
          ; generated by RepRapFirmware Configuration Tool on Mon Aug 21 2017 23:46:40 GMT-0400 (EDT)
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M208 X220 Y236 Z230 S0 ; Set axis maxima
          M574 Z1 S0 ; Define active low and unused microswitches
          M574 X1 Y1 S1 ; Define active high microswitches
          M558 P1 X0 Y0 Z0 H5 F400 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
          G31 P500 X0 Y18 Z2.5 ; Set Z probe trigger value, offset and trigger height
          M557 X15:205 Y15:221 S20 ; Define mesh grid
          M92 X80 Y80 Z800 E418.5 ; Set steps per mm
          M566 X900 Y900 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
          M203 X30000 Y30000 Z1200 E1500 ; Set maximum speeds (mm/min)
          M201 X900 Y900 Z300 E10000 ; Set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M143 S350 ; Set maximum heater temperature to 350C
          M305 P0 T100000 B3950 C0 R4700 ; bed thermistor
          M305 P1 T100000 B4138 C0 R4700 X200 ;
          M307 H1 A543.7 C212.4 D3.7 B0 ; handles PID (hotend)
          M307 H0 A146.3 C421.2 D0.4 B0 ; handles PID (bed)
          M563 P0 D0 H1 ; Define tool 0
          M550 PWheatley ; Set machine name
          M552 S1 ; Enable network
          ; Access point is configured manually via M587 by the user
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          ;M501 ; Load saved parameters from non-volatile memory
          homey.g
          ; homey.g
          ; called to home the Y axis
          ; Lift Z relative to current position
          G91
          G1 Z5 F6000
          G90
          ; Move quickly to Y axis endstop and stop there (first pass)
          G1 Y0 F1800 S1
          ; Go back a few mm
          G91
          G1 Y5 F6000
          G90
          ; Move slowly to Y axis endstop once more (second pass)
          G1 Y0 F360 S1
          ; Lower Z again
          G91
          G1 Z-5 F6000
          G90
          homeall.g
          ; homeall.g
          ; called to home all axes
          ; Relative positioning
          G91
          ; Lift Z
          G1 Z5 F6000
          ; Course home X and Y
          G1 X-225 Y241 F1800 S1
          ; Move away from the endstops
          G1 X5 Y-5 F6000
          ; Fine home X and Y
          G1 X-225 Y241 F360 S1
          ; Absolute positioning
          G90
          ; Go to first bed probe point and home Z
          G1 X15 Y-3 F6000
          G30
          ; Uncomment the following line to lift the nozzle after probing
          G1 Z5 F100
            You have the minimum position for Y set to 0 in your M208 S1 command. This will also be the Y position assumed during Y homing, because you are using a Ymin endstop. You have declared that the grid starts at Y=15 in the M557 command. You have a!so declared that the Z probe has a Y offset of 18 in your G31 command. So the head would have to move to Y=-3mm to probe the first point at Y=15. As this is below the declared Y minimum, the firmware should skip all the probe points at Y=15, but it sounds as though it isn't. I'll re-test this.
              Mentaluproar
              Based on the video I linked to, should Z probe offset Y be a positive or negative value?
                Assuming that +X is to the right, the sensor is offset in the -Y direction from the nozzle, so the probe Y offset should be negative.
                  Mentaluproar
                  Well that’s one problem solved. Thanks. I had it positive.
