    WIFI Disconnection
    • synergy41undefined
      synergy41
      Hello everyone,
      Now that my LITTLE MONSTER and my DUIFF WIFI are practically settled, I still have a little problem that I think is not necessarily serious.
      For some time, I lost the WIFI connection.
      I did not change anything on this side.
      The DWC page loads fine when I turn on the printer and after a while when I go back to look at it the web page display is this:
      If I try to press the CONNECT button in the top left nothing does, I just have a message displayed in red.
      When trying to refresh the page by pressing F5, I have this page that appears:
      Do you have any idea of the problem?
      thanks in advance
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.4.1
      Cura 4.10
        It sounds to me that the WiFi module has lost the connection to your router. Which firmware version are you running?
          synergy41
          I use the 1.19.1. It is enough to turn off and relight the card to find the connection
          I LOVE MY DUET WIFI
          Cura 4.10
          • Yonkimanundefined
            Yonkiman
            I've had (since 1.18; I'm on pre-bug fix 1.19 now) a similar problem where after powering up my PC and my Duet, I have to cycle power to my Duet an additional time to connect.
            • If I power up my Duet before my PC, I have to cycle Duet power before it connects.
            • Strangely, and IIRC (I'm not at my workbench right now so I can't reproduce it) if I power up my PC before my Duet, I still have to cycle power to my Duet to get it to connect (basically applying power to my Duet twice in a row). (I know that doesn't make sense.) EDIT: It didn't make sense because it's not true. If I power-on my PC first, once it's finished booting, I only need to turn on my Duet once.
            It's a very minor problem - I just have to do the additional power cycle as part of turning everything on and it seems to work fine until I power everything down - but I don't remember having to do this with earlier firmware, so it seems to indicate something in the WiFi section has gotten a little "worse" in the last rev or two.
            • chojn1undefined
              chojn1
              I also had some wifi connection issue with 1.19. Setting the IP address, net mask and gateway in the config.g file (M552, M553, & M554) seem to have fixed the problem.
