    Mesh bed leveling
    Using Duet Controllers
    • Turricannundefined
      Turricann
      Is it possible on a duet 3 6hc to atrim each axis manually?
      Reason I ask is when I run 3 point bed leveling it seems to tram the bed but it leave a slight off set on one axis.
        Can you be more specific with what you want to do?
        If you mean can you move one of the Z axis motors independently, then yes you can, you would need to split that driver onto it's own axis temporarily and then move it and then re-combine it.
        Similar to how it was done previously in RRF2
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_2
          Turricann
          When i run 3 point bed traming its as if front left is low by .1mm and rear right is high by around .1mm so the theroy is if i can add a manual offset to on point my bed would be level.
          Motors are positioned Front left and right and one rear center.
            Can you post your config.g, homing files, and bed.g?
            Turricannundefined 1 Reply Last reply Reply Quote 0
              Turricann @Phaedrux
              @phaedrux
              config.g
              ; Configuration file for Duet 3 (firmware version 3.2RC3)
              ; generated by RepRapFirmware Configuration Tool v3.1.10 on Mon Dec 07 2020 21:49:17 GMT+0000 (Greenwich Mean Time)
              G21 ; Work in millimetres
              M550 P"Duet 3" ; set printer name
              M669 K1 ; select CoreXY mode
              G4 S1 ;wait for expansion boards to start
              ; Drives (20.XX) denotes the Can-Bus address that the toolboard LC1 is operating on
              M671 X-4.5:190:478.5 Y-3.52:435:-3.52 P0.2 S5 ; Define positions of Z leadscrews or bed levelling screws Ratrig Stock
              M569 P0.3 S1 ; Duet 3 physical drive 0.0 goes backwards (X)
              M569 P0.4 S1 ; Duet 3 physical drive 0.1 goes backwards (Y)
              M569 P0.0 S0 ; Duet 3 physical drive 0.0 goes Forwards (Front Left Motor)
              M569 P0.1 S0 ; Duet 3 physical drive 0.1 goes Forwards (Middle Back Motor)
              M569 P0.2 S0 ; Duet 3 physical drive 0.2 goes Forwards (Front Right Motor)
              M569 P20.0 S0
              M584 X0.4 Y0.3 Z0.0:0.1:0.2 E20.0 ; 3 * Z motors connected, E20.0 = tool board , Need to keep Z in this order to match lead screw postions.
              M92 X160.00 Y160.00 Z1600.00 E409 ; set steps per mm for Hamera
              M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) ratrig stock
              M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) ratrig stock
              M201 X5000.00 Y5000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) ratrig stock
              M906 X1400 Y1400 Z1400 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
              ;M593 F34.2 <---- look into. ; cancel ringing at 34.2Hz
              M84 S30 ; Set idle timeout
              M208 X400 Y380 Z400 S0 ; set axis maxima
              M574 X1 S3 ; configure sensorless endstop for high end on X
              M574 Y1 S3 ; configure sensorless endstop for high end on Y
              M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch
              M558 P9 C"^20.io0.in" H5 F100 R0.2 T6000 A5 B1 ; set Z probe type to bltouch and the dive height + speeds
              G31 P25 X32.5 Y-42 Z5.492 ; set Z probe trigger value, offset and trigger height
              M557 X35:400 Y30:320 P7 ; define 5x5 mesh grid
              ; Bed Heaters
              M308 S0 P"temp0" Y"thermistor" T100000 B3950K ; configure sensor 0 as thermistor on pin temp0
              ; Hotend Heaters
              M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; Toolboard configure sensor 0 as a E3D thermistor on pin temp0
              M950 H1 C"20.out0" T1 ; Toolboard create nozzle heater output on out1 and map it to sensor 1
              M143 H1 S301 ; set temperature limit for heater 1 to 301C
              M950 F0 C"20.out1" ;Toolboard create fan 0 (Hotend cooling) on pin out1 and set its frequency
              M106 P0 S0 H1 T10 Q500 L255 ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"20.out2" Q500 L255 ; Toolboard (Partcooling) Fan1 on pin out2 and set its frequency
              ; Fan for cooling duet
              M308 S2 Y"drivers" A"DRIVERS" ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
              M308 S3 Y"mcu-temp" A"MCU" ; configure sensor 3 as thermistor on pin e1temp for left stepper
              M950 F2 C"out7" Q100 ; create fan 2 on pin fan2 and set its frequency
              M106 P2 H2:3 L0.15 X1 B0.3 T40:70 ; set fan 2 value
              M563 P0 D0 H1 F0 S"HOTEND" ; define tool 0
              G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets from bed center.
              ;Custom settings are not defined
              ; Linear Advance
              M572 D0 S0.03
              ; Retract
              M207 P0 S1.8 F2400 Z0.3 ; default Hemera retract settings
              T0 ; select first tool
              bed.g
              ; this script compensates for what the Z offset is
              ; so if G31 P500 X-30 Y-15 Z1.7 then first probe will be at
              ; X30 Y20 (when G30 P0 X0 Y5)
              G28
              G30 P0 X35 Y5 Z-99999 ; probe near front left leadscrew
              G30 P1 X200 Y335 Z-99999 ; probe near Rear leadscrew
              G30 P2 X400 Y5 Z-99999 S3 ; probe near Right leadscrew and calibrate 3 motors
              G30 P0 X35 Y5 Z-99999 ; probe near ;front left leadscrew
              G30 P1 X200 Y335 Z-99999 ; probe near ;Rear leadscrew
              G30 P2 X400 Y5 Z-99999 S3 ; probe near ;Right leadscrew and calibrate 3 motors
              G29 ; probe the bed and enable compensation
              G1 X200 Y200
              • fcwiltundefined
                fcwilt @Turricann
                @turricann
                I don't see where you are setting the Z=0 datum with a single G30 to the center of the bed.
                You need to do that:
                • before creating the height map with G29
                • before loading the height map with G29
                • after leveling the bed with using multiple G30s
                You may want to consider splitting the bed leveling and height map creation into the the two files intended for each purpose.
                G29 by itself will run mesh.g (if it exists) so you can put all of the the commands needed to create the height map there.
                G32 by itself will run bed.g (if it exists) so you could put all of the the commands needed to do bed leveling there.
                This is consistent with the commands in the DWC pulldown menu that deals with bed leveling and mesh compensation.
                  Post your homeall
