    Duet2-Ethernet v1.04c Can't connect to dwc
    Duet Web Control
    • carl
      carl last edited by
      Hi these are the error messages I get when I try to connect to DWC for the first time:
      Connection delay(too long)
      DNS_PROBE_FINISHED_NXDOMAIN
      I'm connected to a hub/switch and I manually set my IP with the command M552 Px.x.x.x, through YAT and get a positive feedback (enabled).
      I tried to connect according to the instructions (launch a web browser and enter the IP address, or enter http://duettest.local/ ). Both fail, nothing start, I just get a message "impossible to connect, blah blah"
      Any ideas why it does not work ? I'm using this same hardware model as the link I provided, which is connected to my rooter and all my PC are connected to that switch. The seller told me it should work.
      https://www.amazon.com/Ethernet-Splitter-Optimization-Unmanaged-TL-SG105/dp/B00A128S24/ref=sr_1_2?dchild=1&keywords=switch+tp+link&qid=1623007722&sr=8-2
      SIam 1 Reply Last reply Reply Quote 0
      • SIam
        SIam @carl last edited by SIam
        @carl i don't think that the switch is the problem. Please post your config.g file and the result of M122
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        carl 1 Reply Last reply Reply Quote 1
        • carl
          carl @SIam last edited by carl
          @siam --EDITED--
          here is the M122 result:
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S8-6J1FJ-3SJ6L-T84LK
          Used output buffers: 1 of 24 (2 max)
          Static ram: 27980
          Dynamic ram: 92084 of which 20 recycled
          Exception stack ram used: 256
          Never used ram: 10732
          Tasks: NETWORK(ready,1200) HEAT(blocked,1456) MAIN(running,2712) IDLE(ready,80)
          Owned mutexes:
          Last reset 01:04:32 ago, cause: power up
          Last software reset details not available
          Error status: 0
          MCU temperature: min 35.0, current 38.2, max 38.6
          Supply voltage: min 1.5, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: ok, SG min/max not available
          Driver 1: ok, SG min/max not available
          Driver 2: ok, SG min/max not available
          Driver 3: ok, SG min/max not available
          Driver 4: ok, SG min/max not available
          Slowest loop: 55.24ms; fastest: 0.08ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.3ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "m122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.79ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          Interface state active, link 100Mbps full duplex
          ok
          here is the config.g file
          config.g
          • carl
            carl last edited by
            I ended up installing CuteCom on my linux Desktop and followed the instruction. Configured the Duet IP to DHCP, which didn't worked from windows(I don't know why).
            With linux, it worked like a charm.
            Now I can connect to the DWC from the linux Desktop, windows laptop or via IPad Wifi.
