    Pause delayed heater shut off ?
    Gcode meta commands
    • peter247undefined
      peter247
      I ask this question before , but I don't think it was possible then, is it now on 3.2.2 ?.
      If it goes in to pause mode due to the filament out sensor or trigger I want the heaters to switch off after a set time.
      I've worked out how I program it , in pause.g do what normally happened , after go into while loop wait for state.upTime+timedelay to be greater than State.upTime.
      But the problem is I can store state.upTime+timedelay to make it a variable ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        jay_s_uk @peter247
        @peter247 only in 3.3
        The RC releases are quite stable
          https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Variables
