    Solved One thermistor not working
    • Ian Miller
      Ian Miller last edited by
      My T0 slot is constantly in fault, reading "N/A" for the temp.
      But my T1 slot is working fine. I am able to switch the 2 thermistors present on the board with the same result.
      In duet web control I have 2 heaters mapped to 1 tool, each with their own thermistor:
      M308 S2 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e0temp
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e0heat and map it to sensor 2
      M307 H1 B0 S1.00 ; disable bang-bang mode for heater 1 and set PWM limit
      M307 H2 B0 S1.00 ; disable bang-bang mode for heater 2 and set PWM limit
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M563 P0 S"E0" D0 H1:2 F0 ; define tool 0
      Any ideas what could be causing this?
      • SIam
        SIam last edited by
        @ian-miller said in One thermistor not working:
        you have for both thermistor the same input port (e0temp) defined
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Ian Miller 1 Reply Last reply Reply Quote 1
        • Ian Miller
          Ian Miller @SIam last edited by
          @siam Thanks, thought I had to reference the extruder/tool it accompanied in that line. The problem is gone, thanks a lot.
