    UNSOLVED How can I move a stepper whitch is not on the selected tool
    Using Duet Controllers
    • e4d
      e4d last edited by e4d
      I want to control a stepper motor wired on a Duex/Duet2 system (on E6). I can't find how to do it as it is not on the selected tool (T0).
      Is there some GCODE command that can help me to do that ?
      I want to avoid having to create some "virtual tools" to do that as I'm building a tool changer machine and I would end up taking/replacing the tool too often.
      Thanks
        You could temporarily map the driver to a non-extruder axis and then use a regular G1 H2 move. Does that work for you?
        e4d 1 Reply Last reply Reply Quote 1
        • e4d
          e4d @Phaedrux last edited by
          @phaedrux I did that following your recommandation and it works great for the moment, thanks. The problem I have is that I will build a 5 axis machine so if I understand correctly I will soon run out of available axis.
            How many axis do you think you will need?
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
            • e4d
              e4d last edited by
              5 axis to move the tool and I will have some tools that will require 3 steppers. I also planned to have a stepper that would open an enclosure
