    PanelDue v3 4.3" not connecting after 3.3 RC3 update
    PanelDue
    paneldue not connecting duet2wifi
    1
    • lajosundefined
      lajos
      Hello-
      I upgraded my Duet2 Wifi from 3.0.x to 3.3 RC3 today, and my PanelDue v3 4.3" is not connecting anymore. PanelDue has the latest 3.2.11 firmware. Baud rate is 57600.
      It used to work without any issues on 3.0.x, no change in cabling (using 4 wire cable).
      Any help would be appreciated. Version info and config.g below.
      Thanks-
      Lajos
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3RC3 (2021-05-26)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.3.0-rc3
      ; generated by RepRapFirmware Configuration Tool v2.0.4 on Mon Oct 07 2019 13:27:56 GMT-0400 (Eastern Daylight Time)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"ender5"                          ; set printer name
      ;M551 P"alma1234"                        ; set password
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S1                              ; disable FTP
      M586 P2 S0                              ; enable telnet
      M569 P0 S1                                 ; physical drive 0 goes forwards
      M569 P1 S1                                 ; physical drive 1 goes forwards
      M569 P2 S0                                 ; physical drive 2 goes backwards
      M569 P3 S0                                 ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                           ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                    ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E90.0            ; set steps per mm
      M350 X64 Y64 Z16 E32 I1                    ; update microstepping
      M566 X1200.00 Y1200.00 Z100.00 E600.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z2000.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z500.00 E4000.00    ; set accelerations (mm/s^2)
      M906 X950 Y950 Z950 E1050 I30              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                    ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X220 Y220 Z300 S0                  ; set axis maxima
      ; Endstops X,Y,Z
      M574 X1 S1 P"xstop"   ; X min active high endstop switch
      M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
      M574 Z1 S1 P"zstop"   ; Z min active high endstop switch
      ;M574 X1 Y1 Z1 S1                        ; X,Y,Z set active high endstops
      M308 S0 P"bed_temp" Y"thermistor" T100000 B3950   ; define bed temperature sensor
      M950 H0 C"bed_heat" T0                            ; heater 0 uses the bed_heat pin, sensor 0
      M143 H0 S120                                      ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0_temp" Y"thermistor" T100000 B3950    ; define E0 temperature sensor
      M950 H1 C"e0_heat" T1                             ; heater 1 uses the e0_heat pin and sensor 1
      M143 H1 S280                                      ; set temperature limit for heater 1 to 280C
      ; M307 H1 A335.2 C107.4 D6.2 S1.00 V24.0 B0       ; 205C PID parameters for extruder
      M307 H1 A453.6 C144.9 D5.2 S1.00 V24.0 B0         ; 210C PID parameters for extruder
      ; M307 H1 A384.4 C116.4 D5.6 S1.00 V24.0 B0       ; 250C PID parameters for extruder
      M950 F0 C"fan0" Q25000
      M950 F1 C"fan1" Q25000
      M950 F2 C"fan2" Q25000
      M106 P0 C"fan_e0" S0 H-1              ; extruder 0 fan (controlled from gcode)
      M106 P1 C"fan_e1" S1 H1 T45           ; extruder 1 fan, H1 temp controlled
      M106 P2 C"fan_e2" S0 H-1              ; extruder 2 fan (controlled from gcode)
      M563 P0 D0 H1 F0:2                      ; define tool 0 (D:extruder drive, H:heater, F:fans)
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      ; Pressure advance
      M572 D0 S0.094
      ; BLTouch
      ;M307 H3 A-1 C-1 D-1                   ; Disable heater 3, where BLTouch is connected
      M558 P9 C"^zprobe.in" H4 F100 T5000    ; P:probe type, H:diveheight, F:speed, T:movement between C:connected to zprobe.in (^ for pullup resistor)
      M950 S0 C"exp.heater3"                 ; create servo/gpio 0 on heater 3 pin on expansion connector
      G31 X42 Y0 Z3.65 P25                   ; XY offsets, Z trigger height, P signal filter
                                             ; smaller Z trigger height increases first layer height
      ;M557 X50:170 Y50:170 S40              ; mesh 50-170 step 40
      M557 X45:174 Y45:174 S43               ; mesh 45:174 step 43
      ;M557 P4:4                             ; mesh 4x4
      ;M557 P5:5                             ; mesh 5x5
      lajosundefined 1 Reply Last reply Reply Quote 0
      • lajosundefined
        lajos @lajos
        Additional info: I checked the console on the PanelDue, no messages. Main screen is stuck on "connecting".
        • lajosundefined
          lajos @lajos
          Figured it out. Needed to add M575 to config.g. All good now:
          M575 P1 S1 B57600
