    Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...
    842
    • genebundefined
      geneb @droftarts
      @droftarts said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
      @geneb this may be one of those odd occasions when downloading the firmware afresh (same version) and reflashing the Duet helps.
      I tried reloading Duet2CombinedFirmware.bin again and while the flash process went without issue, the problem remains. 😞
      Fingers crossed that dc42 has some insight.
      tnx.
      g.
        Are you sure the endstop stopped working exactly along with the update to RRF3? And you're 100% sure it's not wiring/crimp/switch?
        You could go back to 2.05.1 if you have your old config and see if it magically starts working again.
        Upload the 2.05.1 zip file to the system tab along with your old config.g
        genebundefined 1 Reply Last reply Reply Quote 0
        • genebundefined
          geneb @Phaedrux
          @phaedrux said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
          I noticed the issue after the update. I've already stated that the machine had been unused for quite some time prior to the update.
          Same issue - X end stop LED remains unlit. No response seen when opening the switch, either vie LED or via M119.
          g.
            dc42 administrators @geneb
            @geneb said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
            If you disconnect the X endstop and use a jumper wire to connect the two outer pins of the X endstop connector together (taking care not to touch the centre pin), does the LED light?
            • genebundefined
              geneb @dc42
              @dc42 said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
              No.
                No.
                In that case, I suspect that either the endstop LED or its series resistor has gone open circuit, or is not properly soldered to the PCB.
                You could try enabling the internal pullup, although this would reduce the noise margin:
                M574 X2 S1 P"^xstop" ; configure active-high endstop for high end on X via pin xstop
                Note the extra ^ character.
                • genebundefined
                  geneb @dc42
                  That's one of the first things I'd tried when trying to work out if I had a configuration error. The behavior didn't change.
                  Is there a repair service for these, or should I just order a replacement?
                  tnx.
                  g.
                    Depends where you are located.
                    https://forum.duet3d.com/topic/13875/community-repairs?_=1623423266311
                    If you're not near any of the ones listed there or not in the UK you might be able to find a local electronics repair or cell phone/laptop repair shop.
                    Or you could use one of the other endstop pins on the expansion header.
                    • genebundefined
                      geneb @Phaedrux
                      So that would be, "no".
                      What part of "I don't want a work-around" is unclear? Stuffing a wire into the expansion header cures the symptom and not the problem. It also prevents future use of the expansion header.
                      I'll just replace the board.
                        Phaedrux Moderator @geneb
                        You're welcome for the helpful suggestion by the way.
