Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...
Depends where you are located.
https://forum.duet3d.com/topic/13875/community-repairs?_=1623423266311
If you're not near any of the ones listed there or not in the UK you might be able to find a local electronics repair or cell phone/laptop repair shop.
Or you could use one of the other endstop pins on the expansion header.
@phaedrux said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
So that would be, "no".
What part of "I don't want a work-around" is unclear? Stuffing a wire into the expansion header cures the symptom and not the problem. It also prevents future use of the expansion header.
I'll just replace the board.
@geneb said in Weird issue after 2.x -> 3.0 -> 3.2.2 upgrade on Duet2 Wifi...:
You're welcome for the helpful suggestion by the way.
